So, I am having an issue. I have a buddy who uses Titan skin (An older version) and when he presses the "i" key from a movie widget the extended info screen pop ups. I am using the latest skin version and also tried the beta version and when I hit the "i" key i get the loading icon for a second then nothing.
Is this a bug in the latest version of the skin?
Hitting the info button will only work if the item is in your library, hitting enter/select will open the extended info screen
EDIT: I hit the info button first as Deadpool as it's my library, then i hit select on the same item it opens the extended info screen
Thank you.
I was hoping to make the feature work if the movies are not in your library.
That would be pretty awesome.
It does work for movies not in library you just press enter/select on the item instead of i/info button
how did you get those round corners on the posters?
It's the modern_rounded theme in Appearance Settings
