Full Version: Changing highlight color in Estuary no longer working
the Estuary announcement said:
https://kodi.tv/a-brand-new-look-for-fut...-versions/ Wrote:[...] After you changed to a certain theme you can still change certain highlights with changing the colour option below the theme setting. [...]
Around the time of the announcement, changing the highlight color was working.
But with some recent nightlies it is no longer working.
Why not?
Regards
It's working for me with latest nightly.
(2016-06-13, 03:52)Guilouz Wrote: [ -> ]It's working for me with latest nightly.
No, it's definitely not working as it used to be working around the announcement.
In:
Settings -> Interface -> Skin -> Theme
I can only choose between:
- Skin default
- curial
And under:
Settings -> Interface -> Skin -> Colours
I can choose between several colors, but those colors change the entire theme color, not just highlights.
Previously you could select a color under "Settings -> Interface -> Skin -> Theme" and then select a highlight color under "Settings -> Interface -> Skin -> Colours".
So you could set yout theme to gray for example and set the highlights to orange for example.
This is no longer working.
Are you sure it's working for you?
Could you possibly provide screenshots?
Regards
It works like that for some time, since estuary update. It's skin color not highlight color.
(2016-06-13, 12:39)Guilouz Wrote: [ -> ]It works like that for some time, since estuary update. It's skin color not highlight color.
But then why did the announcement say:
It was much better with being able to change the highlight color.
Why has it been changed?
(2016-06-14, 13:24)qp9013625 Wrote: [ -> ]
Announcement was written at the very beginning.
Since, background and highlight change with the color.
(2016-06-14, 13:43)Guilouz Wrote: [ -> ]Announcement was written at the very beginning.
But it looks much worse than before now.
Being able to change the highlight color was much better.
How do you know it's not a bug?
Are you an official developer of Estuary?
I thought phil65 would be the official developer...
(2016-06-21, 20:02)qp9013625 Wrote: [ -> ]
Because I follow Estuary from the beginning and I have do a mod of Estuary. So I follow all changes.
It's by intention. That way we can separate themes (=type of textures, flat vs. depth) and colors properly.
