2016-06-14, 03:07
I've really had this issue for years now but its really bugging me lately, files I have in my storage with an ' or similar symbol in it are often not found through nfs on windows. Just a few stupid examples, if I have a file named "Mister Rogers' Revenge" or even worse "Girls' Night" (it gets even worse if it just ends in a ' like Decendants' or something like that) it simply isn't found when importing media. I have to rename the file, remove the ' and then it finds it just fine. The weird thing is that its then often displayed correctly in the file list (e.g. I rename "Girls' Night" which doesn't work to "Girls Night" which does work it then shows up perfectly fine as "Girls' Night" in Kodi) it just doesn't import them.
Is there a way to enable it to just load the files no questions asked or is there a way this could be fixed? I don't always check my files list or even always pay attention to the numbering of my files (or i just cleaned my list and a new file is skipped I don't know in general) which is really annoying because you either miss it or have to manually change everything to make it work...
This same issue goes for other symbols like " or & and such as well but less frequent then the single '.
It also happens with entire directories containing a ' for example I had a directory called Gamers' guide and it wasn't found at all until I changed it into Gamers guide without the '.
Hope someone has a fix for this.
I asked a few people and they say its a simple scripting issue in kodi so I really hope it can be fixed.
