Full Version: "Flickering" when browsing in List Views
Hi there!
First of all, thanks for an awesome Skin! Much wow!
After using it for quite a while, I recognized a bug regarding a "flickering" when browsing through list views. For instance, when going through music albums, the view seems to reload every time I scroll down to the next track, making all the artwork twitch a little. Anybody else having this issue?
Thanks in advance!
This particular issue should be fixed in the current beta version of the skin.
Do you mind giving that a try ?
Thanks, will try asap!
Thanks, so far, the artwork is fixed, but the description of the album still shows the same effect.
(2016-06-15, 17:19)pwriesnik Wrote: [ -> ]Thanks, so far, the artwork is fixed, but the description of the album still shows the same effect.
Can't reproduce. Maybe the info is still beiing cached ? If so, if you have displayed the info once for an item any recurring select should be instant.
