Hi again @
binnugsay
Can you try downloading again the
viewShelfCaseLow.xml above and test. Ive changed a bit of code hopefully the cases will show.
Also theres an image to download also follow instructions for mq7 above.
Hope this works
hi,
the cases appears now.
but the only films that have bluray in name show the logo.
(2016-09-01, 22:49)the_bo Wrote: [ -> ]Hi again @binnugsay
Can you try downloading again the viewShelfCaseLow.xml above and test. Ive changed a bit of code hopefully the cases will show.
Hope this works
Thanks a lot Bo,
Have a test later and said you.
(2016-09-02, 07:56)toutoune290 Wrote: [ -> ]hi,
So does DVD logo not show? Do you have DVD in the name of the movie like Bluray.
I'll have look through code again.
i don't know how the other views know the resolution but we don't have to put any bluray or dvd or other things in the name to work.
(2016-09-02, 09:25)toutoune290 Wrote: [ -> ]i don't know how the other views know the resolution but we don't have to put any bluray or dvd or other things in the name to work.
Thanks for info. I'll compare code to the other views to check.
Cheers
I compared code with other views seem be same for cases.
Can you post a screenshot of a view with the cases working and a screenshot of my view?
Thanks for testing
i'm not in my testing htpc
Hope this works
Hello Bo,
Thanks so much, everything works fine now for cases and for the extension bluray like 2 guns.m2ts, Criminal.ISO for example, we have to put 2 Guns.Bluray.m2ts or Criminal.Bluray.iso if we want to have the Bluray sign on the cases. Perhaps if possible have to put a rolling CD in front of all of the jacket movies, in front of the cases, but more easy to propose as to do. Thanks a lot for the nice Work
Hope this works
Hello Bo,
Here the screen from the case in front of the jacket, very nice. Perhaps. See you
http://imgur.com/a/LcA9Y
http://imgur.com/a/QPMvK
(2016-09-02, 18:51)binnugsay Wrote: [ -> ]Hello Bo,
Hi binnugsay
I've updated code to include disc images. Single disc show on top of the case, while moviesets show in front of case.
Download here try it out
viewShelfCaseLow.xml (Save as xml file)
Enjoy
(2016-09-05, 17:39)the_bo Wrote: [ -> ] (2016-09-02, 18:51)binnugsay Wrote: [ -> ]Hello Bo,
Hi binnugsay
Download here try it out viewShelfCaseLow.xml (Save as xml file)
Enjoy
Hello Bo,
Thanks a lot and works fine. Did you program to have also in front of the case or only on top of the case. Thanks
(2016-09-06, 09:26)binnugsay Wrote: [ -> ] (2016-09-05, 17:39)the_bo Wrote: [ -> ] (2016-09-02, 18:51)binnugsay Wrote: [ -> ]Hello Bo,
Hi binnugsay
Enjoy
Hello Bo,
Heres for disc in front of case
ViewsShelfCaseLow.xml
If you want the disc on top of case again download file on first page.
Enjoy
