Full Version: Created partition on sd card with kodi
Hello,
I have come to you to have an answer to my question
Here I have a raspberry pie 3 with Librelec above
and I use the addons
Quasar
http://koditips.com/quasar-kodi-add-new-...lsar-fork/
for torrents
In the options of the Quasar he asks, or putting the torrent downloaded but it requires the partition to be in NTFS
I know if it was possible to put a partition in NTFS on the same sd card or there is Kodi
Here is my product micro sd card
https://www.amazon.com/SanDisk-Ultra-Mic...B007XZM6VG
If not, I've already try
but Kodi does not start after
I will be able to buy a usb key 64gb but before I try to see if it is possible without usb key
Thanking you
