Hey friends!
Today All of sudden the VideoOSD window is popping up on the DialogSubtitles window when video is paused.
As result I cannot navigate in the DialogSubtitles window unless I resume the video.
Using Jarvis 16.1 on both Windows and OpenELEC.
Skin: Featherence 5.0
Sent from my iPhone
Reverting to Helix 15.2 and issue gone!
Can someone look into it please?
Sent from my iPhone
Hi friend,
What do you mean "all of a sudden?" - as in when you upgraded to Jarvis? I think the pros need more to go on?
Alot has probably changed since Helix. If you are the author of the skin, perhaps you need to have a look at what has changed?
Hey Torben!
Thank you for your reply
Yes issue happen only on Jarvis.
I am the author of the skin idd.
I looked over on the changes from Helix to Jarvis but couldn't find anything related to VideoOSD.xml file alas..
Sent from my iPhone
I am making some progress.
Issue happen when using Action(info) and it's gone when reloading the skin.
Any alternative command perhaps?
I use that command for showing video information on pause. It's require to only be activate once btw.
Sent from my iPhone
Seems odd. If gone on reload it can be fixed. Any xml you think we shoulf see?
Good. Just had a look at your skin.. Looks to be on the advanced side. Looks like you are one of the pros. Heh!
Thanks m8 I am glad you like my work.
Sent from my iPhone
