2016-06-17, 04:53
Hello all,
I am suddenly having problems with either Kodi or my computer or both. I am hoping someone here can point me in the right direction.
Some background info first...
- My HTPC specs are in my signature below. I am running Windows 10 64bit which I upgraded from Win 7 during early April 16. I have had no problems running Win 10
- The computer runs 24/7 and it is not used for anything else except KODI and i access the media content through my iPad and other computer at times.
Two weeks ago I made some changes as follows:
- I moved my setup into my new home theatre room.
- I upgraded my AV Receiver to the new Denon AVR X7200WA with Silver 8 Monitor Audio Speakers and a Krix Volcanix Subwoofer
- Ran new Cat 6 lines from my existing Gigabit Switch to the theatre room and installed a new D-Link 8 port Gigabit Switch to service the TV, AVR, HTPC, and Tivo. (internet is not always connected at the modem. Only as needed. LAN is 24/7)
- Installed a new 4TB WD internal hard drive in my HTPC.
- My previous setup had my TV as the hub for all connections. Now all components are connected into the AVR via HDMI, with one HDMI cable connecting the AVR to the TV.
Every morning since that day two weeks ago I have woken up to a crashed/unresponsive computer. Usually an empty desktop with an unresponsive Task Bar. Some times it is responsive and I just have to right click and close Kodi, restart Kodi and it works fine. Most times I have to force shutdown of the HTPC.
There are three messages displayed on the screen (not at the same time).....
1. Your Computer is Low on Memory. KODI is being shutdown. This is displayed every morning
2. KODI. ERROR: Error caught on main loop. Exiting. This is displayed at varying times.
3. KODI has stopped working. Windows is checking for a solution to the problem. This is displayed at varying times
I have increased the size of my Virtual Memory. Initally to “System Managed” and this did not resolve the problem, so changed it again to “User Set” to a minimum of 4000MB and maximum of 8000MB. This did not solve the problem
I then purchased 16GB of RAM and installed it to give me a total of 24GB of RAM. This did not solve the problem.
I have checked the Windows System Logs and the following events have been logged...
Under Administrative Events
Faulting application name: Kodi.exe, version: 16.1.0.0, time stamp: 0x571c922e
Faulting module name: ntdll.dll, version: 10.0.10586.306, time stamp: 0x571afb7f
Exception code: 0xc0000005
Fault offset: 0x00026d79
Faulting process id: 0x166c
Faulting application start time: 0x01d1c5373cd63463
Faulting application path: C:\Program Files (x86)\Kodi\Kodi.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 339b82c3-aec6-426c-83e3-a87aad49acaf
Faulting package full name:
Faulting package-relative application ID:
Under Windows Logs - Application
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: Kodi.exe
P2: 16.1.0.0
P3: 571c922e
P4: ntdll.dll
P5: 10.0.10586.306
P6: 571afb7f
P7: c0000005
P8: 00026d79
P9:
P10:
C:\Users\HTPC\AppData\Local\Temp\WERBC31.tmp.WERInternalMetadata.xml
C:\Users\HTPC\AppData\Local\Temp\WERBD6C.tmp.appcompat.txt
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_Kodi.exe_53e0604d5d433974db4290bd36289c8c2425f8_f54098db_cab_006bbe25\memory.hdmp
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_Kodi.exe_53e0604d5d433974db4290bd36289c8c2425f8_f54098db_cab_006bbe25\triagedump.dmp
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Status: 100
Hashed bucket:
Under Windows Logs – System
Log Name: System
Source: Microsoft-Windows-Resource-Exhaustion-Detector
Date: 13-Jun-16 05:05:51
Event ID: 2004
Task Category: Resource Exhaustion Diagnosis Events
Level: Warning
Keywords: Events related to exhaustion of system commit limit (virtual memory).
User: SYSTEM
Computer: HTPC-PC
Description:
Windows successfully diagnosed a low virtual memory condition. The following programs consumed the most virtual memory: Kodi.exe (740) consumed 176553984 bytes, AlarmClock.exe (5580) consumed 144035840 bytes, and dwm.exe (1004) consumed 69038080 bytes.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
ALSO...
There are lots of kodi_crashlog-16.1 Git_20160424-c327c53-20160613-215019.dmp files, but I can’t read them. Looks like there is one for each day.
I have uploaded the Kodi Log, It is here...
There are a few kodi_stacktrace-16.1 Git_20160424-c327c53-20160613-215019 files. The contents of the latest one is below...
Thread 2256 (process 5740)
# 0 RtlWaitOnAddress
# 1 RtlEnterCriticalSection
# 2 RtlEnterCriticalSection
# 3
# 4
# 5
# 6 BaseThreadInitThunk
# 7 RtlUnicodeStringToInteger
# 8 RtlUnicodeStringToInteger
I would appreciate some help resolving this problem.
Cab Id: 0
Problem signature:
P1: Kodi.exe
P2: 16.1.0.0
P3: 571c922e
P4: ntdll.dll
P5: 10.0.10586.306
P6: 571afb7f
P7: c0000005
P8: 00026d79
P9:
P10:
Analysis symbol:
Report Status: 100
Hashed bucket:
Log Name: System
Event ID: 2004
Level: Warning
User: SYSTEM
Computer: HTPC-PC
Description:
Event Xml:
ALSO...
# 3
# 4
# 5
