2007-08-19, 12:56
I feel like I'm spamming this forum, atm.
I have a number of small changes I'd like to make to my Home.xml, which as you know uses a Buttonscroller for almost all of its navigation. One of the changes is making the buttons on the scroller optional, so you can turn individual ones on or off depending on preference.
However, I'm being hamstrung at the moment by the lack of visibility controls for individual buttons. I know you can make the entire scroller appear or disappear, but its individual buttons are fixed. A workaround would be to have entirely different Buttonscrollers for each configuration, but the way my Home.xml works (it already switches between three different scrollers) means I can't do it.
Is this option likely at all in the future?
EDIT: Actually, I can see this causing problems. The Buttonscroller would have to know how many buttons were there as each was turned on or off. This would again require an entirely separate scroller for each configuration.
EDIT 2: EDIT RETURNS: I've cracked it, kinda. Don't worry about this for now.
