2016-08-01, 21:32
2016-08-01, 22:11
(2016-08-01, 21:32)djb719 Wrote: [ -> ]question can this skin be used in v16 of Kodi
No sorry this is for Kodi v17 only
2016-08-13, 08:43
If i wanted to just use your pvr mod from here on the other estuary mod, what must i do?
2016-08-26, 00:12
Hey im85288.
Still enjoying your skin.
Just wondering if you plan on keeping things up to date now that they've moved from alpha to beta?
Things like the codec info screen seems to have changed in the newer builds:
http://forum.kodi.tv/showthread.php?tid=276191
2016-08-31, 23:22
The latest Krypton nightlies have introduced a very simple, and I presume, easy to correct issue.
When attempting to play a TV recording, you used to just be able to press enter and it would start playing. In the latest nightlies, they have introduced an intermediate screen that displays more information. On that screen is a "Play Recording" selection. When selecting that, with Estuarized, nothing happens. The screen flashes and then just goes back to the same information screen. I assume that is just because you don't have the logic in there that describes what should happen when the button is pressed. It actually didn't work with Estuary for a couple of days either, but has subsequently been fixed.
2016-09-01, 13:22
Hi Guys,
I'm currently back using Jarvis (due to too many little issues with Krypton) but as soon as that's resolved I'll update the skin to the changes in the base version.
Cheers
Cheers
2016-09-01, 15:24
(2016-09-01, 13:22)im85288 Wrote: [ -> ]Hi Guys,
Cheers
Hey glad to see your still here! Just curious what made you switch back for now? It seems like our setups are pretty much the same (if your still using PKC that is) and mine has been pretty solid as a player other than some of the odd GUI issues (no years in movie node - missing thumbnail in list view - extended info play button doesn't play etc.)
2016-09-01, 15:42
(2016-09-01, 15:24)Hardax Wrote: [ -> ](2016-09-01, 13:22)im85288 Wrote: [ -> ]Hi Guys,
Cheers
Thanks yeah still around but been contributing more to another addon instead: http://forum.kodi.tv/showthread.php?tid=282157 and I moved back to using Emby for Kodi (in place of PKC) as it became evident some of the features I desire (instant update of watch/unwatched status etc were not going to happen). The main reason for sticking on Jarvis though is the usage of the Spotify addon: http://forum.kodi.tv/showthread.php?tid=...pid2405962 not working in Krypton yet. Hoping that will be resolved before Krytpon goes live.
2016-09-03, 15:51
Im85288 I have ran into something with your skin it works perfect on my firestick but when I try to use it on my iPhone plus every shortcut I touch goes straight to the sub menu and when I go bacc to the home screen I can't move the bar up and down to select a new add on it might be because your skin wasn't made for touchscreens or is this a issue that's gonna be fixed later on?
2016-11-22, 03:10
Im85288 is your tweak gonna be updated with the new esturized changes coming up
2016-12-03, 16:50
Guess the skin isn't going to but updated to estuary v2
2016-12-03, 16:56
Hi all, I'm planning on updating the skin in the next few weeks. I haven't kept up to date with what is in Estuary V2 so please feel free to list what additions you think are required in the next update. Cheers
2016-12-03, 17:13
That´s great news im85288, looking forward to an updated version.
2016-12-03, 21:10
(2016-12-03, 16:56)im85288 Wrote: [ -> ]Hi all, I'm planning on updating the skin in the next few weeks. I haven't kept up to date with what is in Estuary V2 so please feel free to list what additions you think are required in the next update. Cheers
Media case option seems broken, don't see the option for it in beta 6. At least I don't anyways.
2016-12-05, 19:26
Happy to hear you're interested in modding EstuaryV2! The baseline skin lacks any real customization, and the Estuary devs will not support it-- they believe the default skin should be very basic.
I would love to see the following added.
- Reorder & rename main menu items
- Customize homescreen widget sets (e.g., I would like to have an Addons widget set to the right of my Video main menu item.)
- Set custom background images and opacity
- Additional color options (I would like a nice deep dark Midnight Blue, personally)
- "Media Info" views like Confluence, with the list on the left
- Other views with the list aligned to the left, including Widelist and List
- Support larger (even comically large) font sizes for small TVs and users with poor vision
- Remove UI cruft with the OSD active. Right now, a black gradient shades the top and bottom fifth of the screen, covering the video output when paused. I often pause video to look at text, etc, and this covers it up.
