Full Version: Estuarized
Pages: 1 2 3 4 5 6 7 8 9 10 11
I was final able to find te download link, upon installing skin, i have found out that it is not touch screen friendly ass i can not scroll between add ons . is there a known fix for this ?? or is it for box use only ?
(2016-07-03, 18:38)djb719 Wrote: [ -> ]I was final able to find te download link, upon installing skin, i have found out that it is not touch screen friendly ass i can not scroll between add ons . is there a known fix for this ?? or is it for box use only ?
Yes this version is targeted at non touch devices, the Estouchy skin is the one to use for touch devices and as far as I am aware there are no mods yet for that skin.
Im85288 Which line of code do I need to change in in the font.xml to change the fonts on the main screen only just the fonts to the main items not the fonts through the whole system
(2016-07-03, 22:41)Short Wrote: [ -> ]Im85288 Which line of code do I need to change in in the font.xml to change the fonts on the main screen only just the fonts to the main items not the fonts through the whole system
It's not quite as simple as that as the fonts are shared throughout the skin (ie main screen and elsewhere) so any change in font.xml will effect everywhere that font is referenced. The safest thing to do is to add a new font set, which items in particular are you looking to change and do you have a new font in mind or is it only the size?
I already have the ttf file of the font I want to use I just want to change the fonts for main menu...also when I try to change the color within the skin it takes forever to load the colors
(2016-07-03, 22:57)Short Wrote: [ -> ]I already have the ttf file of the font I want to use I just want to change the fonts for main menu...also when I try to change the color within the skin it takes forever to load the colors
Ok if you have the ttf file for the font, in font.xml make a new section for that font (copy the default section and rename to what you want to call it) and replace the lato font with the one you want to use. Colour change should not be slow, maybe there's a problem with skin helper.
Thanks for the episode count badge im85288..
I am noticing that some of my shows have a badge showing up on the right hand side with a white number in it? Not all show have it and I can't see anything that this random number would be associated with?
The Estuary skin developers declined to add List (everywhere, including inside libraries) and Media View (with the list on the left side) views similar to what we have now in Confluence. Any chance you could add them?
Example screenshots: http://imgur.com/a/twXbY
Estuary has something comparable to these views, but with the list on the right side, rather than the left. That drives me up the wall!
(2016-07-04, 00:18)Hardax Wrote: [ -> ]Thanks for the episode count badge im85288..
I think that may be the user rating of the show? I have nothing user rated myself so could not say for sure.
(2016-07-04, 03:31)rodalpho Wrote: [ -> ]The Estuary skin developers declined to add List (everywhere, including inside libraries) and Media View (with the list on the left side) views similar to what we have now in Confluence. Any chance you could add them?
Sure, I'll take a look into it and see what can be done.
On the subject of missing artwork...which has recently started with this version and guilloz's mod if anyone still experiences this with version 1.0.12 and are using the latest Alpha build please post here....currently everything works correctly for me, but my suspicion is something in Kodi changed to have this effect.
(2016-07-04, 09:07)im85288 Wrote: [ -> ]On the subject of missing artwork...which has recently started with this version and guilloz's mod if anyone still experiences this with version 1.0.12 and are using the latest Alpha build please post here....currently everything works correctly for me, but my suspicion is something in Kodi changed to have this effect.
Hi
are you in contact with Guilouz to discuss this issue? Did you made any special changes in 1.12 to overcome the issue?
(2016-07-04, 20:30)elchupete Wrote: [ -> ]Hi
Hi, no not in direct contact but I know Guilouz follows my mod to see what he likes for his version. I did make a few changes in particular for poster artwork and one or two for fanart which resolved the issues I was having with the latest alpha release of Kodi...and hopefully that has resolved it but it does seem like it effects different users so very hard to pin point the exact cause of the issue.
(2016-07-04, 20:42)im85288 Wrote: [ -> ]
It's very early in my testing as I only did it this morning but I switched over from the nightly builds to the official Alpha 2 and all my artwork seems to be there now. Even Actor thumbs seem to be more complete than before.
(2016-07-04, 07:34)im85288 Wrote: [ -> ]
That's what it is. Looks like its pulling from Trakt? Is there a way to change the badge style for that one to something more descriptive? Maybe a number within a star?
Hi Hardax,
tried that as well, but didn't work for me
