Full Version: Estuarized
Pages: 1 2 3 4 5 6 7 8 9 10 11
(2016-07-04, 20:42)im85288 Wrote: [ -> ]
(2016-07-04, 20:30)elchupete Wrote: [ -> ]Hi
are you in contact with Guilouz to discuss this issue? Did you made any special changes in 1.12 to overcome the issue?
Hi, no not in direct contact but I know Guilouz follows my mod to see what he likes for his version. I did make a few changes in particular for poster artwork and one or two for fanart which resolved the issues I was having with the latest alpha release of Kodi...and hopefully that has resolved it but it does seem like it effects different users so very hard to pin point the exact cause of the issue.
I have point a possible issue with ListItem.Art(fanart). When I replace '$INFO[ListItem.Art(fanart)]' by '$INFO[ListItem.Art(poster)]' in 'MediaFanartVar' posters are present in background, not with fanart.
Just extrafanarts are working.
All is working on my LibreELEC system, not on my OSX system.
EDIT: I have find the problem.
(2016-07-04, 22:10)Guilouz Wrote: [ -> ]I have point a possible issue with ListItem.Art(fanart). When I replace '$INFO[ListItem.Art(fanart)]' by '$INFO[ListItem.Art(poster)]' in 'MediaFanartVar' posters are present in background, not with fanart.
Cool, glad you found it, the surprising thing is how it only started happening with more recent builds of Kodi
(2016-07-04, 21:23)Hardax Wrote: [ -> ]
(2016-07-04, 07:34)im85288 Wrote: [ -> ]
(2016-07-04, 00:18)Hardax Wrote: [ -> ]Thanks for the episode count badge im85288..
I am noticing that some of my shows have a badge showing up on the right hand side with a white number in it? Not all show have it and I can't see anything that this random number would be associated with?
I think that may be the user rating of the show? I have nothing user rated myself so could not say for sure.
That's what it is. Looks like its pulling from Trakt? Is there a way to change the badge style for that one to something more descriptive? Maybe a number within a star?
Most likely I'll move that away completely from there and have the user rating at the bottom with the other ratings...I think this will be cleaner?
(2016-07-05, 09:02)im85288 Wrote: [ -> ]
(2016-07-04, 07:34)im85288 Wrote: [ -> ]I think that may be the user rating of the show? I have nothing user rated myself so could not say for sure.
Yeah I think thats a good idea.
On another note would it be possible to make the ending time of a movie/show a little more prominent in the upper right of the screen. My aging eyes have a hard time seeing it? No problem if you feel it will compete with the overall look of course. Same thing with all the various ratings services and clear art along the bottom? They seem terrible small.
(2016-07-05, 14:18)Hardax Wrote: [ -> ]
(2016-07-04, 21:23)Hardax Wrote: [ -> ]That's what it is. Looks like its pulling from Trakt? Is there a way to change the badge style for that one to something more descriptive? Maybe a number within a star?
Yeah I'll take a look and make the ratings etc at the bottom bigger, I think it's because I test on a 70 inch screen I never see any issues but I'll enlarge them a bit to prevent sore eyes Smile
The ending time, do you think a bigger font or maybe a different font/colour? Not sure about that one yet
(2016-07-05, 19:14)im85288 Wrote: [ -> ]
(2016-07-05, 09:02)im85288 Wrote: [ -> ]Most likely I'll move that away completely from there and have the user rating at the bottom with the other ratings...I think this will be cleaner?
Maybe just a bit bigger/bolder to offset it from the current time thats right above it? Another option is to move it away from the clock and put it next to the duration time? Make logical sense to look for it there doesn't it?
couldn't install your repo
(2016-07-05, 19:48)Hardax Wrote: [ -> ]
(2016-07-05, 14:18)Hardax Wrote: [ -> ]Yeah I think thats a good idea.
I did try making it bold briefly and wasn't happy with how it looked....will look further into it this weekend.
(2016-07-07, 00:20)Edworld Wrote: [ -> ]couldn't install your repo
That's a shame, I have no valid reason for you not being able to install it but if you would like to provide more details I will attempt to assist you further.
Did you use the download link at the bottom of im85288 page on Git? I have had zero luck installing things from Git using the Clone to Desktop or ZIP feature. I think it changes the folder structure when it compresses the files. im85288's download link at the bottom of the page has always worked fine for me though.
I used the link on the first post "my repo" and downloaded from GIT - download zip
Install from zip file and got the following error:
(2016-07-08, 00:34)Edworld Wrote: [ -> ]
On that Git page scroll all the way down and click the huge green "download" button. See if that download works if it's not the one you originally used.
(2016-07-08, 03:27)Hardax Wrote: [ -> ]On that Git page scroll all the way down and click the huge green "download" button. See if that download works if it's not the one you originally used.
Thanks, that worked!
this will not work on Jarvis?
Nope gotta be on krypton alpha 2 at the least but it's in beta
Everything was working fine till a few days ago first the skin erased all my settings so I fixed that now my multi imagine background is showing pictures not even in the folder I set it too and when I set it on a folder it shows the wrong folder what going on done uninstalled and reinstalled
