2016-07-21, 13:07
2016-07-21, 16:01
(2016-07-21, 01:58)LloydShow Wrote: [ -> ]Great skin. Loving it at the moment. Any chance you could implement Movie and TV Hubs?
Thanks, glad your enjoying it. I'll put them on my possible todo list
(2016-07-21, 13:07)alazabe Wrote: [ -> ]Why It cant be install in libreelec?
I did install the repo and when i download
It show me the download failed !
I have no idea why it would fail...my test devices are all windows but see no reason why it would fail to install on libreelec.
2016-07-21, 16:55
great mod...
but can't find Tv Next SHow aired widget ...
2016-07-21, 19:50
(2016-07-21, 16:55)telexxingou Wrote: [ -> ]great mod...
Cheers, I think I'll add that to the tv hub...seems like a nice place to place it.
2016-07-22, 14:27
Quick question im85288. I was playing around with custom widgets on my home screen but decided I liked the stock widgets better. Is there an easy way to get back to those without reinstalling the skin completely? They don't seem to just be standard nodes that I can pick from a menu.
Skin seems to be working great for me BTW. Thanks again!
2016-07-22, 14:49
(2016-07-22, 14:27)Hardax Wrote: [ -> ]Quick question im85288. I was playing around with custom widgets on my home screen but decided I liked the stock widgets better. Is there an easy way to get back to those without reinstalling the skin completely? They don't seem to just be standard nodes that I can pick from a menu.
Yeah it's not very intuitive but setting them back to None resets it back to the default ones.
Glad all is good...next release will contain Movie and TV hubs
2016-07-22, 20:24
Version 1.0.21 is now in the repo
Headline changes for this version are the inclusion of both Movie and TV Hubs (turn them off in skin settings....you may need to reset the home menu if you have already configured it for them to show up), all the menu items for the hubs can be configured along with choosing what widget is shown. Other little tweaks here and there are included too
watch gallery
2016-07-23, 00:37
Thanks for the movie hubs im85288!
2016-07-23, 00:59
(2016-07-23, 00:37)LloydShow Wrote: [ -> ]Thanks for the movie hubs im85288!
Your welcome, good suggestion! I think it works very well especially since I removed the sub menu icons from the home screen to improve the ergonomics of the skin. It also allowed me to squeeze in the tv next aired in a logical place.
2016-07-23, 03:27
Liking the Hubs too!
A couple little glitches I've noticed. When the Movie Hub is activated, the duration field in the item description screen is empty.
Also, now that I have activated the Hubs there doesn't seem to be any way to turn them off. Selecting the "don't use Movie Hub..." in settings gets rid of the word "hub" from the main menu item but when you select it, instead of just bringing you to the movie node/list, it brings you to the Movie Hub.
2016-07-23, 11:52
(2016-07-23, 03:27)Hardax Wrote: [ -> ]Liking the Hubs too!
Thanks for reporting, the strange thing is on one of my machines I can turn them off and on the other I cannot!! Will see if I can spot what's up...worst case scenario I may leave the hubs as default (yes one more click to get to all movies but not that bad I think)
I'm also going to change the next up display to match the skin better
2016-07-23, 13:34
A quick update to version 1.0.23 as I noticed extra fanart is not working (at least on my machines) currently so this update should resolve blank backgrounds in the media library. I have also removed quite a few images/flags that are not suited to this version.
2016-07-23, 16:19
Im85288 I was wondering are you gonna keep this skin simple or are u gonna add every feature and make this a skin that uses a lot of memory...jus asking love the skin btw
2016-07-23, 17:27
(2016-07-23, 16:19)Short Wrote: [ -> ]Im85288 I was wondering are you gonna keep this skin simple or are u gonna add every feature and make this a skin that uses a lot of memory...jus asking love the skin btw
Thanks buddy, I'm pretty happy with most things as they are now...next area in mind to change is the next up stuff. The memory intensive things (in particular the fancy backgrounds can be turned off) but in general I will use as many features from the skin helper addon as I feel add value to the skin. Bear in mind my target is obviously the machines I use (which are powerful htpc's) but if there are any particular areas that create problems for low powered devices (such as the PI etc) then please let me know and I'll do my best to resolve that.
In the end this mod is my personal view of how I like things (I cannot control if the other mod incorporates my changes) but if anyone pops in with a good idea to improve things I will always consider it if it adds value
2016-07-23, 21:45
im85288, any chance you can place my clear case mod into your mod with an option to enable for those who want it? Also Nextup Notification isn't working on my Android box, but it does on my Windows 10. I did 3 fresh reinstalls for android,but still doesn't work.
