Pages: 1 2 3 4 5 6 7 8 9 10 11
(2016-07-23, 21:45)Repoman Wrote: [ -> ]im85288, any chance you can place my clear case mod into your mod with an option to enable for those who want it? Also Nextup Notification isn't working on my Android box, but it does on my Windows 10. I did 3 fresh reinstalls for android,but still doesn't work.
Yeah sure can you send me the mod or a link to where the changes are and I'll look to incorporate them as an optional extra.
With regards nextup not working on android, from what I understand there are quite a few krypton issues with android at the moment so can only imagine it is down to that. If, once krypton is released and the problem is still there then please post about it in the nextup thread (link in signature).
(2016-07-23, 22:12)im85288 Wrote: [ -> ] (2016-07-23, 21:45)Repoman Wrote: [ -> ]im85288, any chance you can place my clear case mod into your mod with an option to enable for those who want it? Also Nextup Notification isn't working on my Android box, but it does on my Windows 10. I did 3 fresh reinstalls for android,but still doesn't work.
Clear Case Mod
(2016-07-23, 22:23)Repoman Wrote: [ -> ] (2016-07-23, 22:12)im85288 Wrote: [ -> ] (2016-07-23, 21:45)Repoman Wrote: [ -> ]im85288, any chance you can place my clear case mod into your mod with an option to enable for those who want it? Also Nextup Notification isn't working on my Android box, but it does on my Windows 10. I did 3 fresh reinstalls for android,but still doesn't work.
Clear Case Mod
Cool, it just so happens my next up changes are similarish to yours. I'll take a look tomorrow sometime cheers.
Version
1.0.24 is in the repo
As stated earlier this version changes the next up (both live tv and my addon version) and also includes the clear case mod from @
Repoman.
Development will slow down for the foreseeable future, but any major bugs etc found please report, cheers.
Were you able to figure out why duration time is missing on the video info screen only when using the hubs im5288? Not a huge deal but a little inconvenient at times.
Otherwise I agree that the skin is perfect as it is. Just enough features but still nice and clean like the original.
Ah sorry forgot about that one, I'll try and take a look quickly tonight as hopefully it's an easy fix. Thanks for the reminder.
(2016-07-24, 17:43)im85288 Wrote: [ -> ]Ah sorry forgot about that one, I'll try and take a look quickly tonight as hopefully it's an easy fix. Thanks for the reminder.
While your at it I just noticed that all the ratings at the bottom seem to be gone now? Both in the main video node list and the details screen.
(2016-07-24, 18:05)Hardax Wrote: [ -> ] (2016-07-24, 17:43)im85288 Wrote: [ -> ]Ah sorry forgot about that one, I'll try and take a look quickly tonight as hopefully it's an easy fix. Thanks for the reminder.
Yeah I've just noticed the same...all skin helper functions do not seem to be working in the main video library or details screen...I'm updating to the latest kodi nightly to see if that makes any difference.
(2016-07-24, 18:25)im85288 Wrote: [ -> ] (2016-07-24, 18:05)Hardax Wrote: [ -> ] (2016-07-24, 17:43)im85288 Wrote: [ -> ]Ah sorry forgot about that one, I'll try and take a look quickly tonight as hopefully it's an easy fix. Thanks for the reminder.
If it means anything I haven't updated anything other than your skin. Still on Krypton alpha 2 and Skin Helper 1.0.90
(2016-07-24, 19:00)Hardax Wrote: [ -> ] (2016-07-24, 18:25)im85288 Wrote: [ -> ] (2016-07-24, 18:05)Hardax Wrote: [ -> ]While your at it I just noticed that all the ratings at the bottom seem to be gone now? Both in the main video node list and the details screen.
Yeah I'm noticing strange stuff at the moment, upgrading to skin helper 1.0.99 helps partially in that the info is shown on the details screen and all works in the video library as long as you do not navigate there via the hubs...still investigating how/why that would impact it. But for now I'd advise getting the latest skin helper version.
Version 1.0.25 is now in the repo with the duration fix. The problem with not showing anything from skin helper when navigating via the hubs still remains but I've run out of time to try and resolve that. I'll come back to it at a later stage though. Cheers.
For anyone struggling to turn off the hubs you can replace the file found in the shortcuts folder with this one:
https://dl.dropboxusercontent.com/u/4689...u.DATA.xml
I'll come back to this most likely next weekend so this should help until then.
I'd also be interested to hear if anyone else (apart from @Hardax) cannot turn the hubs off either.
Cheers
Im85288 I tried this skin on my tablet and I found out it's not very touchscreen friendly
thanks....
I see it in TV HUB to launch TV Next show aired script...but can't find how to add it in widget
is possible ?
thank you
(2016-07-21, 19:50)im85288 Wrote: [ -> ] (2016-07-21, 16:55)telexxingou Wrote: [ -> ]great mod...
but can't find Tv Next SHow aired widget ...
Cheers, I think I'll add that to the tv hub...seems like a nice place to place it.
Version
1.0.27 is now in the repo.
The issue with ratings on the hubs has now been resolved.
I now plan to leave this version as it is to avoid the bloat that other mods often get by adding every feature (suitable or not! to the skin)
Cheers guys
