Full Version: Apple Music addon?
Are there any addons that allow Apple Music streaming in Kodi? Saw that they had released the api not long ago.
If you want to stream Apple Music on Kodi, you need to remove DRM from Apple Music so that you can just playing Apple Music by turning on the converted files folder and playing it via TuneFab Spotify Music Converter.
Know more detail: http://www.tunefab.com/tutorials/apple-music-kodi.html
That’s not streaming. That’s downloading and converting everything. Any way to login and stream?
Due to the DRM protection, Kodi does not support the add-on for Apple Music contents playback. But it is feasible if the Apple Music contents can be converted to your personal audio files.  And here is the alternative solution you can take a reference:
http://www.sidify.com/guide/play-apple-m...-kodi.html
or you could just play to kodi from your pc or mobile via airplay. no other way.
p.s. i actually went from apple music to spotify just because i couldn't have apple music in my kodi and there was no way i was gonna convert all the music i added there - also i would then have to convert every time i add something to my apple music and that's just a lot to deal with.
It seems that there is no Apple Music add-on yet. It may failed when you add Apple Music to Kodi directly because of DRM. Now you can convert Apple Music to unprotected audio formats like MP3, AAC, WAV and FLAC and then import the converted Apple Music to Kodi. http://www.tune4mac.com/apple-music-tips...-kodi.html
this still not possible?
I use a website playapplemusic.com while at work. would be great to discover a kodi solution that's similar for my lounge. Don't fully understand the drm element, but if a website can do it why can't kodi?....
