Full Version: WeTek Hub - 24p HD Netflix - HD Kodi Audio - 10bit HEVC - Lollipop - 4K
Here is new Android Marshmallow 6.0.1Development build firmware for WeTek Hub
WeTek Hub - Android MM 6.0.1 07.02.2017
What is new:
- Latest Android MM 6.0.1 changes from S905X backported to S905
- Few fixes in Kernel
- This build is fully compatible with Kodi v17 including fix for H.265 10 & 8bit playback
This build support dual-boot function, although it is not displaying on boot instructions for pressing Power button at RCU, but if you keep it pressed, for sure it will boot it to LibreELEC/OpenELEC.
** wrxtasy ** does a wee jig !!! Smile
Thx. Now we are getting somewhere. Yesterday's Popcornmix 64bit Kodi memleak fix for LibreELEC and now a Dual Boot capable Android MM update with the possibility of up to 4K - 7.1 DD+ Android TV OS Netflix.
Time to look at the Log and see if the backported IEC Audio code made it in as well.
Kodi Krypton 17.0 final which uses Android mediacodec Hardware acceleration.
- Kodi Dynamic Refresh Switching - Broken
- 8/10bit HEVC (H265) playback - Working
- Improvements in 1080/25i H264 deinterlacing. (TvHeadend) - PCM or HDMI (no Auto) must be selected in Android Audio settings.
- 1080/25i mpeg2 deinterlacing - Broken (TvHeadend) - 576i will default to high quality YADIFx2 Software deinterlacing.
SPMC 16.5.5:
Using amcodec & mediacodec acceleration options.
- Kodi Dynamic Refresh Switching - Broken - However you can select Resolutions and Refresh Rates from within SPMC.
(However doing that in SPMC that has its own problems with HDCP and my 4K TV setup)
- H264 playback - Working
- Hardware deinterlacing for OTA TV viewing - Working with AC3 Audio passthrough.
- Easy Dual Boot Android/LibreELEC - Works ! - the proper Dual Boot screen shows up. Smile
There still is the erroneous NAND shown on the splash screen when it should be eMMC. Attention to detail is important !
- Netflix Android TV OS standard v3.3.2 - Works without modifications. 2.0 PCM Audio only with my DD+ capable TV.
HDMI connected AVR's I'm told will give 7.1 DD+ Audio output. Also 4K Netflix should now work as well.
(Mi Box gives me the the 5.1 Audio Icon in Netflix with a DD+ TV)
Further usage..and this Android MM Development Build has quite a few GUI non response issues at random times....but now after what looks like what must have been low level housekeeping after Firmware installation, its settled down into a reasonably quick platform.
- No IEC HD Audio Support ...just the normal Android API level 23: AC3, EAC3, DTS, DTS-HD support...
16:16:28.312 T:18446744073188022576  NOTICE: special://profile/ is mapped to: special://masterprofile/
16:16:28.312 T:18446744073188022576  NOTICE: -----------------------------------------------------------------------
16:16:28.312 T:18446744073188022576  NOTICE: Starting Kodi (17.0 Git:20170201-a10c504). Platform: Android ARM 32-bit
16:16:28.312 T:18446744073188022576  NOTICE: Using Release Kodi x32 build
16:16:28.312 T:18446744073188022576  NOTICE: Kodi compiled Feb  1 2017 by GCC 4.9.0 for Android ARM 32-bit API level 21 (API level 21)
16:16:28.312 T:18446744073188022576  NOTICE: Running on WeTek Hub with Android 6.0.1 API level 23, kernel: Linux ARM 32-bit version 3.14.29
16:16:28.312 T:18446744073188022576  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
16:16:28.312 T:18446744073188022576  NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
16:16:28.313 T:18446744073188022576  NOTICE: Product: wetekhub, Device: wetekhub, Board: p200_2G - Manufacturer: WeTek, Brand: WeTek, Model: Hub, Hardware: amlogic
16:16:28.318 T:18446744073188022576  NOTICE: External storage path = /storage/emulated/0; status = ok
16:16:28.318 T:18446744073188022576  NOTICE: ARM Features: Neon enabled
16:16:28.319 T:18446744073188022576  NOTICE: special://xbmc/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
16:16:28.319 T:18446744073188022576  NOTICE: special://xbmcbin/ is mapped to: /data/user/0/org.xbmc.kodi/cache/apk/assets
16:16:28.319 T:18446744073188022576  NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-2/lib/arm
16:16:28.319 T:18446744073188022576  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
16:16:28.319 T:18446744073188022576  NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
16:16:28.319 T:18446744073188022576  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
16:16:28.319 T:18446744073188022576  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
16:16:28.319 T:18446744073188022576  NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
16:16:28.320 T:18446744073188022576  NOTICE: The executable running is: /data/app/org.xbmc.kodi-2/lib/arm/libkodi.so
16:16:28.320 T:18446744073188022576  NOTICE: Local hostname: localhost
16:16:28.320 T:18446744073188022576  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
16:16:28.320 T:18446744073188022576  NOTICE: -----------------------------------------------------------------------
16:16:28.321 T:18446744073188022576  NOTICE: load settings...
16:16:28.361 T:18446744073188022576   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
16:16:28.370 T:18446744073188022576 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
16:16:28.396 T:18446744073188022576   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
16:16:28.398 T:18446744073188022576   DEBUG: Firmware implements AC3 RAW
16:16:28.398 T:18446744073188022576   DEBUG: Firmware implements EAC3 RAW
16:16:28.398 T:18446744073188022576   DEBUG: Firmware implements DTS RAW
16:16:28.398 T:18446744073188022576  NOTICE: AML device detected
16:16:28.399 T:18446744073188022576   DEBUG: AESinkAUDIOTRACK - 32000 supported
16:16:28.402 T:18446744073188022576   DEBUG: AESinkAUDIOTRACK - 44100 supported
16:16:28.403 T:18446744073188022576   DEBUG: AESinkAUDIOTRACK - 48000 supported
16:16:28.404 T:18446744073188022576   DEBUG: AESinkAUDIOTRACK - 96000 supported
16:16:28.405 T:18446744073188022576   DEBUG: AESinkAUDIOTRACK - 192000 supported
16:16:28.405 T:18446744073188022576   DEBUG: Firmware implements DTS-HD RAW
16:16:28.405 T:18446744073188022576  NOTICE: Found 1 Lists of Devices
16:16:28.405 T:18446744073188022576  NOTICE: Enumerated AUDIOTRACK devices:
16:16:28.405 T:18446744073188022576  NOTICE:     Device 1
16:16:28.405 T:18446744073188022576  NOTICE:         m_deviceName      : AudioTrack
16:16:28.406 T:18446744073188022576  NOTICE:         m_displayName     : android
16:16:28.406 T:18446744073188022576  NOTICE:         m_displayNameExtra: audiotrack
16:16:28.406 T:18446744073188022576  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
16:16:28.406 T:18446744073188022576  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
16:16:28.406 T:18446744073188022576  NOTICE:         m_sampleRates     : 32000,44100,48000,96000,192000
16:16:28.406 T:18446744073188022576  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_RAW
16:16:28.406 T:18446744073188022576  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_DTSHD
Tried it.
I also have a Xiaomi Mi 3 box with Android 6. It seems the MI has HDR video support while this one doesn't
Hi @wrxtasy
how did you manage to dual boot with the latest MM update? I can no longer boot kszaq's libreelec from sdcard.
I always get a "error in mount_flash: mount_common: could not mount /dev/mmcblk0p1"
(2017-02-08, 15:46)davedeluria Wrote: [ -> ]Tried it.
That would be because the Mi Box has a S905X where as the Hub has a S905 with no HDR support on that particular SoC.
HDR really is not that important for AMLogic as the only properly encoded 4K HDR10 entertainment sources for the Mi Box are from Netflix. Which cannot be streamed until there is an Android Nougat update. Unless you like to watch HDR test clips on a repeat loop.
(2017-02-08, 16:04)mmpp Wrote: [ -> ]Hi @wrxtasy
I think I ran into the same problem. I may have had kszaq's LE on a SD card and the Dual Boot Splash screen would not even show up.
Had me scratching my head for a while there.
I reflashed a SD Card with Raybuntu's 32bit Hub beta2 Kodi Krypton Final, from HERE
You could probably just do a LE .tar backup of your current @kszaq LE 32bit version. Reflash RB's 32bit image and restore the backup .tar
Thanks for the tip, raybuntu's release boots fine. But now the remote no longer works - apparently this is a bug introduced by switching from amremote to lirc.
Have you checked Programs > LibreELEC Configurator > Services I think it is.
There may be a Lirc enable switch in some versions that needs toggling.
(2017-02-08, 16:08)wrxtasy Wrote: [ -> ]That would be because the Mi Box has a S905X where as the Hub has a S905 with no HDR support on that particular SoC.
Noted. I shoot 4K Video (photography buff) so I use the boxes to play them back.
(2017-02-08, 17:02)wrxtasy Wrote: [ -> ]Have you checked Programs > LibreELEC Configurator > Services I think it is.
Thanks for your support. I should have been more specific.
Yes, lirc is running and recognizes the remote. I can use the navigation and sound buttons, but the "ok" button is not recognised.
Found the source of my boot problem: I forgot to copy the correct device tree to the sdcard. Sad
Dual boot works fine with this new beta.
(2017-02-08, 02:46)wrxtasy Wrote: [ -> ]- Kodi Dynamic Refresh Switching - Broken
SPMC 16.5.5:
just sigh,.. nothing else. when they'll learn that this is not enough to get the CUSTOMERS satisfied.
(2017-02-07, 23:45)droidelec Wrote: [ -> ]- Latest Android MM 6.0.1 changes from S905X backported to S905
The last line is even just a LIE: see above, nothing fully compatible when for example kodi refresh rate switching is not working
(2017-02-08, 20:39)lama0900 Wrote: [ -> ]
SPMC 16.5.5:
You did see the words "development build" when they announced it didn't you
(2017-02-08, 21:14)goujam Wrote: [ -> ]
SPMC 16.5.5:
Of course I read that but:
development or not...This issue is known since almost half a year.
AND btw: This does not change the fact being lied to when saying fully compatible bla
@lama0900 which issue is it you want sorted for almost 6 months ? I'm pretty happy with my play 2 frame rate switching works and so does HD audio. I am however using the unofficial android TV ROM but it's based on weos 1.3
