Full Version: WeTek Hub - 24p HD Netflix - HD Kodi Audio - 10bit HEVC - Lollipop - 4K
(2017-03-19, 13:44)Vlaves Wrote: [ -> ]
(2017-03-18, 06:28)wrxtasy Wrote: [ -> ]...
Amcodec hardware acceleration still works when using Kodi Jarvis for us OTA TV viewers that have deinterlacing issues with Kodi Krypton and PVR clients.
I'm testing with SPMC v16.5.5
Why not newest SPMC 16.6.0?
Actually I re-checked and I am actually using the latest SPMC 16.6.0
Extra Good News - this MM Firmware has Google IEC61937 Audio Support for comprehensive HD Audio passthrough (untested):
11:16:05.209 T:18446744073184479536  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:16:05.209 T:18446744073184479536  NOTICE: -----------------------------------------------------------------------
11:16:05.209 T:18446744073184479536  NOTICE: Starting SPMC (16.6-0 Git:2017-03-01-68a86a2-dirty). Platform: Android ARM 32-bit
11:16:05.209 T:18446744073184479536  NOTICE: Using Release SPMC x32 build
11:16:05.209 T:18446744073184479536  NOTICE: SPMC compiled Mar  1 2017 by GCC 4.9.0 for Android ARM 32-bit API level 21 (API level 21)
11:16:05.209 T:18446744073184479536  NOTICE: Running on WeTek Hub with Android 6.0.1 API level 23, kernel: Linux ARM 32-bit version 3.14.29
11:16:05.209 T:18446744073184479536  NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0-spmc
11:16:05.209 T:18446744073184479536  NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
11:16:05.209 T:18446744073184479536  NOTICE: Product: wetekhub, Device: wetekhub, Board: p200_2G - Manufacturer: WeTek, Brand: WeTek, Model: Hub, Hardware: amlogic
11:16:05.226 T:18446744073184479536  NOTICE: External storage path = /storage/emulated/0; status = ok
11:16:05.226 T:18446744073184479536  NOTICE: System library paths = /vendor/lib:/system/lib
11:16:05.226 T:18446744073184479536  NOTICE: App library path = /data/app/com.semperpax.spmc16-2/lib/arm
11:16:05.226 T:18446744073184479536  NOTICE: APK = /data/app/com.semperpax.spmc16-2/base.apk
11:16:05.230 T:18446744073184479536  NOTICE: HasTouchScreen = yes
11:16:05.231 T:18446744073184479536  NOTICE: ARM Features: Neon enabled
11:16:05.231 T:18446744073184479536  NOTICE: special://xbmc/ is mapped to: /data/user/0/com.semperpax.spmc16/cache/apk/assets
11:16:05.231 T:18446744073184479536  NOTICE: special://xbmcbin/ is mapped to: /data/user/0/com.semperpax.spmc16/cache/apk/assets
11:16:05.231 T:18446744073184479536  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/userdata
11:16:05.231 T:18446744073184479536  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc
11:16:05.231 T:18446744073184479536  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/temp
11:16:05.232 T:18446744073184479536  NOTICE: The executable running is: /data/app/com.semperpax.spmc16-2/lib/arm/libspmc.so
11:16:05.235 T:18446744073184479536  NOTICE: Local hostname: localhost
11:16:05.235 T:18446744073184479536  NOTICE: Log File is located: /storage/emulated/0/Android/data/com.semperpax.spmc16/files/.spmc/temp/spmc.log
11:16:05.235 T:18446744073184479536  NOTICE: -----------------------------------------------------------------------
11:16:05.236 T:18446744073184479536  NOTICE: load settings...
11:16:05.272 T:18446744073184479536   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
11:16:05.281 T:18446744073184479536 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
11:16:05.298 T:18446744073184479536   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
11:16:05.301 T:18446744073184479536   DEBUG: AESinkAUDIOTRACK - 32000 supported
11:16:05.301 T:18446744073184479536   DEBUG: AESinkAUDIOTRACK - 44100 supported
11:16:05.302 T:18446744073184479536   DEBUG: AESinkAUDIOTRACK - 48000 supported
11:16:05.303 T:18446744073184479536   DEBUG: AESinkAUDIOTRACK - 96000 supported
11:16:05.303 T:18446744073184479536   DEBUG: AESinkAUDIOTRACK - 192000 supported
11:16:05.303 T:18446744073184479536    INFO: AESinkAUDIOTRACK - ENCODING_IEC61937 detected
11:16:05.304 T:18446744073184479536  NOTICE: Found 1 Lists of Devices
11:16:05.304 T:18446744073184479536  NOTICE: Enumerated AUDIOTRACK devices:
11:16:05.304 T:18446744073184479536  NOTICE:     Device 1
11:16:05.304 T:18446744073184479536  NOTICE:         m_deviceName      : AudioTrackPCM
11:16:05.304 T:18446744073184479536  NOTICE:         m_displayName     : Android
11:16:05.304 T:18446744073184479536  NOTICE:         m_displayNameExtra: PCM
11:16:05.304 T:18446744073184479536  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
11:16:05.304 T:18446744073184479536  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
11:16:05.304 T:18446744073184479536  NOTICE:         m_sampleRates     : 32000,44100,48000,96000,192000
11:16:05.304 T:18446744073184479536  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_FLOAT
11:16:05.304 T:18446744073184479536  NOTICE:     Device 2
11:16:05.305 T:18446744073184479536  NOTICE:         m_deviceName      : AudioTrackPT
11:16:05.305 T:18446744073184479536  NOTICE:         m_displayName     : Android
11:16:05.305 T:18446744073184479536  NOTICE:         m_displayNameExtra: IEC Passthrough
11:16:05.305 T:18446744073184479536  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
11:16:05.305 T:18446744073184479536  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
11:16:05.305 T:18446744073184479536  NOTICE:         m_sampleRates     : 32000,44100,48000,96000,192000
11:16:05.305 T:18446744073184479536  NOTICE:         m_dataFormats     : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3,AE_FMT_TRUEHD,AE_FMT_DTSHD
11:16:05.305 T:18446744073184479536  NOTICE:     Device 3
11:16:05.305 T:18446744073184479536  NOTICE:         m_deviceName      : AudioTrackPTRAW
11:16:05.305 T:18446744073184479536  NOTICE:         m_displayNameExtra: RAW Passthrough
11:16:05.305 T:18446744073184479536  NOTICE:         m_dataFormats     : AE_FMT_AC3_RAW,AE_FMT_EAC3_RAW,AE_FMT_DTS_RAW,AE_FMT_DTSHD_RAW
Android 6.0.1 MM has arrived: http://www.wetekforums.com/v/index.php?p...0-1#latest
Postat cu Tapatalk
(2017-03-24, 14:58)Axelro Wrote: [ -> ]Android 6.0.1 MM has arrived: http://www.wetekforums.com/v/index.php?p...0-1#latest
Postat cu Tapatalk
And it's awesome!
Much more fluid and stable.
Now the recommendations are turned off by default and the device works better now.
On Android 5.1.1 was a bit sluggish
Hi to all, newbie here. I want to install LibreELEC to internal nand, as i want the Hub performing as a pure Kodi engine. What is preferable, the official Libreelec 8.0.1 or any other custom LibreELEC version like Kszaq's or Raybuntu's ? Thanks in advance.
All three versions are OK, of course you can start with official version from LibreELEC.tv
(2017-04-11, 17:37)ako78 Wrote: [ -> ]Hi to all, newbie here. I want to install LibreELEC to internal nand, as i want the Hub performing as a pure Kodi engine. What is preferable, the official Libreelec 8.0.1 or any other custom LibreELEC version like Kszaq's or Raybuntu's ? Thanks in advance.
You can always check first using mSD card
Check which version is more liking to your needs.
But on any of them should be OK and working without any major issues
BR
However its a bit like Ghostbusters - don't cross the streams.
Those streams equating to official LibreELEC 64bit releases vs the 32bit @kszaq and @Raybuntu LibreELEC releases.
Addon binaries are not compatible between 64bit<<-->>32bit - as such its advised to stick with what you start LE with unless you want to get your hands a wee bit dirty !
The script found over here is what you run first before doing a LE .tar update to flop between 32/64bit releases:
Krypton 32/64bit upgrade instructions.
Thank you all for advice. Finally, i installed the official libreELEC. Blush
Great, if you have any questions, feel free to ask!
Best regards
Finally Android TV ROM 2.0 has been released for the Hub Smile Smile
Here are some of the major points in this release:
  • Added back the HDMI-CEC language option to HDMI-CEC settings and disabled it by default No more automatically switching to Korean
  • HD audio passthrough works correctly in apps like Netflix, Plex etc
  • DTS-HD is automatically downgraded to DTS if your AVR doesn't support it (except in Kodi)
  • Dolby Digital Plus is automatically downgraded to Dolby Digital if your AVR doesn't support it (except in Kodi) This way, people can still enjoy Netflix in 5.1 without a supported AVR
  • Improved playback in Kodi and other apps that change the refresh rate
  • Don't do HDMI renegotiation everytime we switch channels on "Live Channels" or skip a video in SPMC wth Amcodec
  • Xiaomi Mix Box remote works out of the box, including the power button (mic doesn't work yet)
Thanks ricardopvz also from here for this great work you have done Smile
MOD Edit - had to correct the Android spelling in the title, it was hurting my brain reading !
Yes @ricardopvz has done a great job here Again !
We have been testing and tweaking over about the last month or so.
This ATV ROM is actually better than WeTek's WeOS so far as Android TV OS App Audio handling and SPMC / Kodi Krypton video Sync is concerned.
Also I'm particularly pleased OTA TV using SPMC & the Live Channels App now works properly after I did some Sherlock work. Wink
When used with the paired Mi Box remote, I actually prefer this ROM over the actual Mi Box for Android TV Apps like Netflix and Kodi.
Refresh switching and Video Sync are superior.
I can Root this ROM too to be able to use my PS3 remote for Retro gaming.
Plus you still get to dual boot into LibreELEC Kodi Krypton - Win Win ! Smile
Chromecasting is unsupported as you need an actual Android TV OS Chromecasting certificate.
Wetek has to pay Ricard for his work and dedication.
With this rom I have audio sync in kodi/spmc and netflix?
1GB of ram is enough on android for retro games (friend, PS1)?
Enviado do meu ALE-L21 atrav├ęs de Tapatalk
RE Android TV rom
I noticed this post about bugs - "the very first Skipping of video will still cause a HDMI renegotiation, Kodi Krypton & SPMC. Subsequent skips do not cause this." and wondered if this is why I see a frame of static when skipping on my Hub running LE?
And Android MM for play 2 still far far away :-(
(2017-05-17, 17:34)zbigzbig20 Wrote: [ -> ]And Android MM for play 2 still far far away :-(
Hum... Is it? Wink
Soon... very Soon...
