2016-06-21, 10:01
Hello,
I am quite new with Kodi. Running latest version on an Android TV box, serving from a NAS (running Twonky).
From what I can understand, Kodi does a library scan and basically puts all similar files into the same 'folder' and things like that. In my case it is missing terribly, mixing up music and tv shows, or not showing all video files found in a folder for some reason (while they are all named correctly, I use FileBot for that)
So the question, summing up: Is there a way to use Kodi as a file explorer, not scanning my library whatsoever? I have a correct file structure, don't need any of that. I found online that there should be a 'file mode', but I could not find more detailed information about it.
