Hello
In the Handbook is written:
"Media Sources are virtual links to the content you wish Kodi to use. When you enter any of the Videos, Music, Pictures or the Filemanager..."
http://kodi.wiki/view/Media_Sources
My Kodi display only "Addons". I reinstall und reboot Kodi. No Result. When i try over "Videos" then "Files" i can choose between the Scraper
"Nothing"
"Movies"
"TV Series"
"Musicvideos"
But no Scraper named "Pictures".
It was working bevor for months. One day i can't show my Pictures. I spend 2 days to try a lot of solution.
I don't ask for a reason. Only for a solution.
Thanks a lot for every hint
Greetings
schwarzch
You don't make picture sources in videos menu. Go to pictures menu, files, add source.
Hello
Is that a Joke?
I wrote "My Kodi display only "Addons". That means i go to the Menuitem "Picture".
And there is only one Subitem: "Addons"
"Add Files" is not displayed
I reinstall Jarvis 16.1. The same result.
I remove Kodi with Windows Installer. The same result.
I remove the folder "Kodi" in the User Section. The same result.
What you suggest?
Reinstall Windows? Format Systempartition? Buy a new PC?
Greetings
schwarzch
Use a VHS system lol....
Have you add source in other sections?
Take a look at system, appearance, file lists. Maybe you have "show add source button" not flagged.
And as nickr wrote you have to go in picture section. There you will find add pictures. That's all
Hi
VHS or better Hyper V? ;-)
Yes i can ... add Files to other Sources. Only the Menu Picture not display the Menuitem "Add Source".
You wrote:
"system, appearance, file lists. Maybe you have "show add source button" not flagged."
This Option is active
The Default Skin "Confluence" is activ. Language "english" or "german".
In my "Picture" Section or Root Menu Item is only "Addons"
I can post Screenshots, if that helps.
Or i take a Umbrella and buy a new PC ;-)
Greetings
schwarzch
Hello
Tonight i post Screenshot and Logfile.
On the Screenshot you can see the root item "Picture" and one Submenuitem "Addons".
Greetings
schwarzch
In the first picture you have bilder highlighted. Google translate tells me this means images or pictures. At that point press OK on the remote or enter on the keyboard. You should get a menu with 'add source'. If not, go up a level , ie click on ..
Hello
Thank you so much for your help.
With "Enter" the "Add Picture Menu" will be displayed.
I was definitly my fault. In the Wiki is written "When you enter any of the Videos, Music, Pictures or the Filemanager, .." and not realize that.
RTFM ;-)
Greetings
schwarzch
(2016-06-30, 19:56)schwarzch Wrote: [ -> ]With "Enter" the "Add Picture Menu" will be displayed.
RTFM ;-)
So what's the magic remote control sequence to simulate ENTER instead of OK ?
I'm using a Bravia TV which has a remote control, and alternatively I can use the Kodi Remote app on my phone. Neither of which has an ENTER button. I tried pressing and holding OK, but that doesn't make the Add Pictures menu display.
