Full Version: Not loading on android
So, as of now I am not completely sure this is skin related, but here is my issue I am currently having.
I updated one of my builds that is using the Titan skin and I see that Titan has also been recently updated.
Here is my issue. My build will download and extract just fine on windows and run no problem.
When I go to try and install the build onto an android device, it installs then stops extracting around 7% and tells me to force close like it should being an android device.
When i reboot, its as if nothing installed and boots up to the default confluence skin. No addons, no programs, images, etc.
Anyone have any insight to this issue?
Start with installing the skin from the repo to see if that works.
You're talking about builds which is not very likely to be supported around here
