(2016-10-22, 15:20)springroll Wrote: [ -> ]What a great looking skin!
Would you consider adding Arial as a font selection? I would love to be able to display Unicode Chinese and Japanese characters from my library and add-ons. Thank you!
Hi emre.ay - would you be open to consider the suggestion above too?
(2016-10-28, 16:06)springroll Wrote: [ -> ] (2016-10-22, 15:20)springroll Wrote: [ -> ]What a great looking skin!
Added to my to do list[emoji106]
Hey hey,
I'am again
Next thing I saw in your Skin that looks not really original is the Font unter the Tiles in the Home-View.
I think they are little to big or to bold or both
Thank You for your awesome work at this point...
I cant get widgets to work on kodi 17 android i set the shortcuts but nothing shows on the shell?
(2016-10-30, 17:32)makita86 Wrote: [ -> ]I cant get widgets to work on kodi 17 android i set the shortcuts but nothing shows on the shell?
Do you have skinwidgets installed ?
(2016-11-04, 07:59)Steverae Wrote: [ -> ] (2016-10-30, 17:32)makita86 Wrote: [ -> ]I cant get widgets to work on kodi 17 android i set the shortcuts but nothing shows on the shell?
I didn have skinwidgets that was the problem i installed it and thewidgets show but now widgets wont open.When i click on a poster nothing happens?
I have been working on an update for tvoxs since i think is a great skin and hate to see it die. hopefully you can use my updates to keep the design going i noticed your zoom animation on the home screen icons is chunky you can use the animation on my update for a smooth zoom and slow zoom out i have the same animation throughout like with the shelf labels and list icons in fanart and episode views i also made perfect positions for shelf covers and and fanart and icon covers and video info. Have included very good backgrounds for white and dark and redesigned the video full screen. i hope you can use for krypton i updated it.
Textures
http://www.fast-files.com/getfile.aspx?file=124911
Jarvis
http://www.fast-files.com/getfile.aspx?file=124912
Krypton
http://www.fast-files.com/getfile.aspx?file=124913
Hey broadfield,
maybe you can make some screenshots of your updates.
I think that better for us to
imagine your improvements.
Thanks...
Gesendet von iPhone mit Tapatalk
(2016-11-05, 22:08)broadfield Wrote: [ -> ]I have been working on an update for tvoxs since i think is a great skin and hate to see it die. hopefully you can use my updates to keep the design going i noticed your zoom animation on the home screen icons is chunky you can use the animation on my update for a smooth zoom and slow zoom out i have the same animation throughout like with the shelf labels and list icons in fanart and episode views i also made perfect positions for shelf covers and and fanart and icon covers and video info. Have included very good backgrounds for white and dark and redesigned the video full screen. i hope you can use for krypton i updated it.
Textures
Jarvis
Krypton
Thanks for the update!
But PLEASE - use another filehoster! Those fast-files-links are horrible... Can't get to download anything. Just popups and security warnings.
Textures
Jarvis
Krypton
Thanks for your work. I will take a look
I 've installed this skin on latest kripton nightly and the widgets on the shell wont open?Am i missing some dependency ?When i click on movie poster nothing happens.Any help?
