2016-07-14, 20:34
(2016-07-14, 18:52)bigbadrabbit Wrote: [ -> ]I think you'd have to go with skin.shortcuts script. But that's probably complicated to implement / replace with the current home layout.
Yes it is the right script
(2016-07-14, 18:52)bigbadrabbit Wrote: [ -> ]I think you'd have to go with skin.shortcuts script. But that's probably complicated to implement / replace with the current home layout.I will look what can I do
(2016-07-14, 22:30)iRubin Wrote: [ -> ]Really cool stuff!It is Possible. Maybe you can make with Photoshop one picture how do you mean that. Would be helpful
Is it possible to change the background of the weather item to something more natural?
Maybe a color like the typical sky-color with a little blur effect?!
(2016-07-15, 05:52)Steverae Wrote: [ -> ]I've also suggested having a look at fTV as 'tis is an awesome looking skin which has a lot of cool stuff in like the ability to change the size of the posters displayed onscreen etcI will look
Sent from my iPhone
(2016-07-14, 15:49)emre.ay Wrote: [ -> ]Please, would it be possible to have a version or option not to use any phyton scripting in the skin. Havin MrMC in mind which is basicly Kodi 16 without phyton so its Apple App store compatible. But it would be awsome to have that Skin integrated there.(2016-07-14, 15:45)Frep Wrote: [ -> ]Very nice! About home customization, it will be the same as the other Apple TV skin? For example it is possible to put any shortcut? Like favs, addons and subsections of addons. And above the preview of the shortcut, If I put series shortcut it will show its content? Like my series. I mean like Titan skin, netflix homescreen 2 subthemeYeah for now it would be the same. Maybe I find a new concept for that
(2016-07-15, 17:53)Vlaves Wrote: [ -> ]Please, would it be possible to have a version or option not to use any phyton scripting in the skin. Havin MrMC in mind which is basicly Kodi 16 without phyton so its Apple App store compatible. But it would be awsome to have that Skin integrated there.
(2016-07-15, 21:02)Doc.Ex Wrote: [ -> ](2016-07-15, 17:53)Vlaves Wrote: [ -> ]Please, would it be possible to have a version or option not to use any phyton scripting in the skin. Havin MrMC in mind which is basicly Kodi 16 without phyton so its Apple App store compatible. But it would be awsome to have that Skin integrated there.
I reckon apple won't allow any software in the app store that tries to completely imitate their tvOs interface.
(2016-07-17, 18:50)Jakeround98 Wrote: [ -> ]Hey,Very helpful thanks
I'm working on a tvOS application too, I thought i'd share some of the stock background images used in the system to support your skin.
http://www.jakeround.com/tvOS/
Hope it helps.
(2016-07-25, 14:04)bigbadrabbit Wrote: [ -> ]I'd like to know too!Have you Screenshots for your VideoViews.xml?
Anyway, here's my modified Videoviews.xml of iCanuck's unfinished tvOS-X-skin. I've modified the poster view to mimic ATV4's look. It's not perfect as the animations need to be tweaked a little bit further. But maybe you can use it, at least partly.
