Full Version: Lost all watched episodes despite Trakt
I had been trying out trakt with my kodi install and it seemed to be syncronising fine. I had to do a fresh install of kodi because of various bugs and thought my trakt account would hold onto all of my watched statuses but it hasnt.
On any other device Trakt is still up to date with what I have watched but I can't seem to get kodi to sync to it
I was having issues with the trakt addon not syncing my movies/shows, even though it said it was pulling info and syncing. Long story short, I deleted the addon and it's settings folder, reinstalled and reconfigured. Boom, working again. Not sure what could've happened, but that is what I had to do to get it working again.
Thanks I'll give it a try. Where is its settings folder?
AppData\Roaming\Kodi\userdata\addon_data\name of addon
Did this work out for you?
Yes, Remove Trakt addon from the User Addons works great and everything is working fine before the corruption happened. On a Fire Stick, you have to use ES Explorer for the removal. Thank you so much.
