Full Version: Can't order channels in guide
Hi all, I've set up Kodi to run with an ArgusTV backend and have had no trouble so far except for being able to order the channel list in the guide.
I've tried using the channel manager in System\Settings\LiveTV\General\Channel Manager but the guide goes back to a 'default' alphabetical order even though I make sure I'm saving the settings.
I've confirmed that the guide is in the correct order in ArgusTV.
I've searched for other posts and have found some where people have suggested ticking a box to force Kodi to use the back-end's channel order but it doesn't seem to be an option in my build. I'm using Kodi 16 with Aeon Nox.
I would appreciate any help.
Not saying this will definitely help, but it's worth changing back to confluence skin to see if the 'use backend order' option re-appears.
Should be under Settings->TV->General->'Use channel order from backend(s)'
You could also try updating to the latest and greatest version of your skin.
Thanks. I changed back the the Confluence skin and changed the setting to use channel order from the back end but had no joy.
