Full Version: AppleTV 4 - Kodi 17 Subtitles Problem.
I have side-loaded Installed Kodi on AppleTV 4 (With out Jail Broken) seems to be working Fine.
Some other the Subtitle Plugins works fine too. but i am big fan of "Subsecene.com" but its unfortunate in TvOS subsecene don't seems to be working, i have tried to and load the downgraded version of Subsecene Subtitles 1.7.0 (Current is 1.7.1) but neither current version neither the downgraded version work.
I mean they do get installed but when searching for certain move subtitles the search results are "Zero" i have again "Factory Rest the ATV4 and second time tried to use the subsecene but no luck.
Any one have ideas why it could be happening.
NB:- I have used the Kodi Deb for TvOS latest version normally available on github (Compiled on 22-May-2016)
Because the site uses https://
any site that uses https:// does not work with KODI 17 Until now
I do not know why but sites with http:// It works
You mean Subsecene.com uses "https" and due to that it is not working ?
