Full Version: Background dim problem
Hello everybody.
I've been using Nebula skin (dark theme) for a long time on my Osmc - Raspberry2 system. Today, for no apparent reason, all the backrounds are not dimmed as they used to be so the screen is almost unreadable... I tried to play around with theme settings->background transparency percentage but it doesn't change anything... I've even restored a complete Kodi backup from a couple of days ago, and still background images are 100% bright.
Can anyone point me to a possible solution?
Have you already tried to reset the skin settings to defaults?
Tgx
Hey TGX... Thanks for your reply, and for the great skin!! Smile
I solved the problem by removing and reinstalling the skin...
Anyway... That was pretty weird, as if I switched to the bright theme, everything was fine... Getting back to the dark theme it was screwd up...
