Full Version: Kodi/Chorus Searching for Cast?
Hey Guys,
im new to this, but i have some knowledge in Programming with CSS/PHP/C#/SQL...
but i couldnt find what i was looking for
The Chorus Web Interface search function.
Why?
Because i would like to add the cast to the result.
I tryed to add the "movie_view" within the MyVideos99.db
PHP Code:
CREATE VIEW movie_view AS
SELECT  movie.*
sets.strSet AS strSet
,  sets.strOverview AS strSetOverview
,  files.strFileName AS strFileName
,  path.strPath AS strPath
,  files.playCount AS playCount
,  files.lastPlayed AS lastPlayed
,   files.dateAdded AS dateAdded
,   bookmark.timeInSeconds AS resumeTimeInSeconds
,   bookmark.totalTimeInSeconds AS totalTimeInSeconds
,   actor.name AS actor
FROM movie
    LEFT JOIN sets ON    sets
.idSet movie.idSet
            JOIN files ON    files
.idFile=movie.idFile
            JOIN path ON    path
.idPath=files.idPath
            JOIN actor_link
AS al ON al.media_id movie.idMovie
            JOIN actor ON actor
.actor_id al.actor_id
            LEFT JOIN bookmark ON    bookmark
.idFile=movie.idFile AND bookmark.type=1
        GROUP BY c00
As you can See i added some LEFT JOINS to add the actors and actor_link table
but it had not the effect i was hoping
The Problem is, i cant find the "Trigger" where the SQL Statements where activated when im typing into the search bar.
Can anyone Help me?
Thx so far
greetings
xquadradpi
You should be using JSON-RPC just like chorus does.
I would,
if i would know where to change/to use it
How i said i could not find the Files where to change the search statement
Here the documentation of the API for JSON-RPC: http://kodi.wiki/view/JSON-RPC_API/v6
Here the source of chorus2: https://github.com/jez500/chorus2
you need to know at least a litte javascipt and maybe jquery.
i have some good basics in js and jquery
i was using Chorus 1
was checking the Chorus.js but could not find the way how to change the "search filters" so that actors will be included to the search results :/
