Hi there,
Im would like to set string as follows
xbmc.executebuiltin("Skin.SetString(AddonSetSeven.3.Path,PlayMedia("plugin://plugin.video.someaddon/?url=27&;mode=125&name=News&iconimage=http%3A%2F%2Fstatic.website.com%2Fcouch%2Fchannels%2F27%2Fextra_big_logo.png&start=na&ch_fanart=na",return))")
but when I run the python program it adds extra & as follows
PlayMedia("plugin://plugin.video.somaddon/?url=27&;mode=125&name=News&iconimage=http%3A%2F%2Fstatic.website.com%2Fcouch%2Fchannels%2F27%2Fextra_big_logo.png&start=na&ch_fanart=na",return)
breaking the shortcut. I have masked addon and website on purpose in case it can't be mentioned here.
I hope I have explained ok
how can i stop this please. Thank-you for any assistance.
i don't think you want that xml encoding. the xml encoding is because skin stuff is usually stored in xml files.
you want
xbmc.executebuiltin("Skin.SetString(AddonSetSeven.3.Path,PlayMedia(\"plugin://plugin.video.someaddon/?url=27&mode=125&name=News&iconimage=http%3A%2F%2Fstatic.website.com%2Fcouch%2Fchannels%2F27%2Fextra_big_logo.png%26start=na%26ch_fanart=na\",return))")
ie. escaped quotes (due to python), and url-encoded url (due to url-in-url). but no xml encoding.
(2016-06-30, 13:57)ironic_monkey Wrote: [ -> ]i don't think you want that xml encoding. the xml encoding is because skin stuff is usually stored in xml files.
you want
Ironic_Monkey,
thats almost done it. thanks. the only problem Im getting now is
NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.NameError'>
Error Contents: name 'ch_fanart' is not defined
File "/home/usuario/.kodi/addons/plugin.video.someaddon/default.py", line 1164, in <module>
play_***mon(name, url, iconimage, ch_fanart)
NameError: name 'ch_fanart' is not defined
I have checked, double checked and compared with similar strings from the same addon the only difference seems to be that the good entry ends as so
**correct ending**extra_big_logo.png&start=na&ch_fanart=na",return)</setting>
but what I am getting is
**bad ending** extra_big_logo.png%26start=na%26ch_fanart=na",return)</setting>
so it seems the problem is with the
any more ideas please, Thank you for the help.
(2016-06-30, 15:06)myfototv Wrote: [ -> ] (2016-06-30, 13:57)ironic_monkey Wrote: [ -> ]i don't think you want that xml encoding. the xml encoding is because skin stuff is usually stored in xml files.
you want
Ironic_Monkey,
Problem Solved wherever there is a
just leave the
and remove
when uning the
Thank you Ironic Monkey for helping me to solve this
