Full Version: 3D SBS mode does not turn off during profile change
I tried to create a second user profile specifically for 3D content. It has its separate library sources with just 3D media (95% half sbs)
Since I have to change my projector's mode manually every time I start a 3D movie, I figured I would make the 3D profile be in 3D SBS mode all the time (kodi menus and everything).
It works great. I change the mode on the projector only once in the beginning and everyone can keep their glasses on while browsing through the menus, etc.
However, when I switch back to the original profile, kodi does not turn the 3D SBS mode off even though the profile is set to use the 2D view. I have to go into the settings and manually change it (settings show 2d selected, have to change it to something else first, and then back to 2d)
I believe this is a bug. Should I report it elsewhere?
PS. I'm using libreelec 7.0.1 (haven't tested 7.0.2 yet but I doubt it's fixed in that)
