2016-07-03, 17:35
While setting up modelines for my new TV I noticed that some of my 25fps HEVC encoded videos were detected as 100fps according to the Kodi log:
As you can see above, this makes Kodi change the refresh rate to a non-optimal 60Hz refresh rate rather than 50Hz.
If I at any time during playback press "o" to show the codec info, Kodi will show "fr:25.000".
Full debug log:
http://pastebin.com/raw/epUNGbgC
If I run mediainfo against the file, the output tells that the "Frame rate mode" is variable and between 14.286fps and 25.000fps. I suppose this is what confuses Kodi...or is the 100fps a hardcoded value used by Kodi whenever a variable frame rate is detected, to ensure selection of the highest refresh rate possible?
http://pastebin.com/raw/Fzzayi3g
While I think it would make better sense for Kodi to default to 50Hz or 25Hz, when fps tops at 25.000, then I suppose that there isn't much to do about it, besides avoiding videos with variable refresh rate?
16:53:54 T:140129104537344 NOTICE: fps: 100.000000, pwidth: 720, pheight: 404, dwidth: 720, dheight: 404
16:53:54 T:140129104537344 DEBUG: OutputPicture - change configuration. 720x404. framerate: 100.00. format: VAAPI
16:53:54 T:140129104537344 DEBUG: Resolution 3840x2160@ 50.00 - Full Screen (16) not a very good match for fps 100.000 (weight: 0.500), trying 2:3 cadence
16:53:54 T:140129104537344 DEBUG: Resolution 3840x2160@ 50.00 - Full Screen (16) not a very good match for fps 100.000 with 2:3 cadence (weight: 0.800), choosing 60 hertz
16:53:54 T:140129104537344 NOTICE: Display resolution ADJUST : DP1: 3840x2160_60.00 @ 60.00Hz (27) (weight: 0.400)
Full debug log:
