2016-07-04, 10:04
Hardware
Mac Mini - Mid 2011 - 2.3GHz i5 - Intel HD Graphics 3000 - 16GB RAM
Software
OS X - El Capitan 10.11.5
Kodi 17.0-ALPHA3 Git:2016-07-03-3409787
Issue
First installed Alpha 2, same issue on current nightly - noticed when playing a video file there was choppy playback, audio is fine.
Dumped userdata and tested a fresh setup, same issue.
Now, if I activate any type of onscreen overlay, i.e. info screen or codec info the video plays perfectly, but only while activated. When closing overlays the video is choppy again.
I have a Macbook Pro - Late 2011 - 2.4GHz i5 - Intel HD 3000 512MB - 8GB RAM running OS X 10.11.6 [beta] and this does not exhibit the same issue.
Not sure what else to try to troubleshoot this.
Logs: http://pastebin.com/WWYMEhkB
Media Info
Software
Issue
Media Info
General
Unique ID : 22585479421793991561144899407688459389 (0x10FDCE1BDD4B5AF187C868B1FBF3647D)
Complete name : /Volumes/Qmultimedia/TV/Top Gear/Season 23/Top Gear - S23E05 - Episode 5.mkv
Format : Matroska
Format version : Version 2
File size : 1.59 GiB
Duration : 1h 2mn
Overall bit rate : 3 658 Kbps
Writing application : Stupid Ocelot
Writing library : Stupid Ocelot / Stupid Ocelot
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 2mn
Bit rate : 3 393 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.147
Stream size : 1.48 GiB (93%)
Writing library : x264 core 148 r2694 3b70645
Encoding settings : opencl=1 / cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 2mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Compression mode : Lossy
Stream size : 85.5 MiB (5%)
Default : Yes
Forced : No
