Hi all,
This used to work, but now since upgrading to a v17 version, Kodi no longer adjusts my display's refresh rate.
Here is debug log while I tried playing back a 23.976 fps MKV.
I'm on latest release - v17 alpha (git). Running Kodibuntu, Samsung LCD TV, Yamaha surround received, pass-through enabled.
All help is welcome!!
Some more info:
System info
dpkg -l |grep mesa
DISPLAY=:0 vainfo
I'm using an
Intel i5-3550 Ivy Bridge CPU with HD2500 graphics, connected to my Yamaha RX-V773 received via HDMI. Motherboard is an
H77-based Asus board.
I'm seeing the video play back at 23.976fps in kodi, and I get 1 or 2 dropped frames over the timespan of a couple minutes.
Key settings:
Adjust video to display rate: Always
Sync playback to display: Off
Allow hardware acceleration - VDPAU:
ON
Allow hardware acceleration - VAAPI:
OFF
VAAPI doesn't work for me - I get no video.
I suspect that this does not work because VAAPI is off, something which was broken in the previous Kodi release.
I also suspect that my GPU (HD2500) might be a problem here, since it's known to struggle with the 24p issue.
Perhaps upgrading to a CPU with HD4000 GPU would make the troubles go away?
Update:
Got it to work, had to upgrade VAAPI version using ppa wsnipex/vaapi (got this from
http://forum.kodi.tv/showthread.php?tid=231955).
Then had to set "Deinterlace video" to ON and "Deinterlace method" to "Deinterlace" during playback - no other interlacing methods worked.
24p refresh rate sync issue is resolved, but playback is now kinda choppy.. CPU usage is around 30-40% on all four cores.
For anyone interested, my issues were caused by VAAPI decoding not working due to the outdated graphics stack in Ubuntu 14.04. I upgraded to 16.04 and did some further tweaks to get VAAPI working in kodi 17. See here for more info:
http://forum.kodi.tv/showthread.php?tid=...pid2383363
