Full Version: Kodi 17 Alpha 2 /Video Library issue
Hello,
I've been testing Kodi 17 Alpha 2 ( very good job btw! ), and I found what I think is a bug in the video library:
When removing a video source, the "files" and "actors" tables are not cleared in MyVideos106.db, even if the file is removed from the folder.
Step to reproduce :
- Add a video (movie) source, with at least one video named accordly best practice
- Check if the video is correctly seen
- Delete the video source
- Check the database : entries in the "files" and "actors" table remains
I also tried to clean the database, but without any success. Is that the normal process or is it really a bug ?
Should you need the logs, please ask, and tell me please if there's any specific component to log
