Full Version: Confluence (streaming audio addon) STATS won't turn off
Hi.
I signed up to the forum just now to ask: How can I turn the stats off while in fullscreen mode during streaming audio from an addon, like say Digitally Imported?
The Stats that are constantly on the screen are:
"Audio codec: aac - Bitrate: 49kbps - Bits/sample: 32 - Sample rate: 44.1kHz - Audio channels: 2
fps: 59.52"
And I cannot find anything for turning it off. So I can no longer listen to any audio addons because I don't want these Stats burnt into my television screen.
Please, someone tell me how to turn these stats off in Krypton - Confluence skin.
Alternatively I can blank the screen I guess. I wan't to see vizualizations again.
It's fixed in master but hasn't been pushed to the repo yet.
https://github.com/xbmc/skin.confluence
Well good thing it is fixed and making it's way to the repo.
Thanks Hitcher for the quick reply.
Because Github is like a foreign country to me, I don't where to go and I don't know the language they speak, so I can't figure out how to get anything from Github. I've never tried.
How soon till the fix is on the Repo?
Edit: I figured it out, was pretty easy, just download the zip file and install it into Kodi. Thanks again Smile
@Banteel
If you are a fan of Confluence, you might want to give:
http://forum.kodi.tv/showthread.php?tid=242892
a try. It also has the fix included! Smile
I may give Confluence Z a try. I noticed it in the Get More list. Thanks for the recommendation.
I don't know if you use some kind of custom prebuild KODI system, but as far as i know the Skin is not part of any "Get more"-Skin-list since it's not in the official (Skins)-repo.
Standard installation method would be via my repo zip-file (which provides auto-updates)
https://github.com/axbmcuser/_repo/raw/m...mcuser.zip
(See thread for simple installation instructions) Smile
You are correct. I must thought I'd seen on the list.
