Full Version: Re-scraping only some information
Hi folks,
I have been using xbmc/kodi for more than three years now, and have a collection of several hundreds of movies. I have all my library exported to .nfo files locally saved on the movie directory. I have been finding that some movies have outdated information e.g. the link to the trailer is not working as the video on youtube has been removed. I do not want to rescrap all the library as it will take ages and will also remove some tweaks I made, as fixing the genres and changing the poster image. I am sure that an add-on exists that updates only certain pieces of information (the vote and so on), but - for the life of me - I cannot remember its name. Someone can help me out?
Thanks,
Gio
(2016-07-09, 09:23)buongiorgio Wrote: [ -> ]Hi folks,
Thanks,
Gio
I've got myself an answer as far as regards ratings. The imdb update plugin should do the trick (just found it, I will try it in next days). But as far as regards the trailer, still no luck.
(2016-07-23, 09:30)Wimpie Wrote: [ -> ]Try Ember Media Manager:
Indeed, it did the trick, thanks.
