2017-02-22, 03:24
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
2017-02-22, 08:01
(2017-02-17, 16:14)primaeval Wrote: [ -> ](2017-02-17, 15:46)gillmacca Wrote: [ -> ]Let's see if any of you guys can come up with a solution for this.
In the uk, we have sky movie channels. Some of the channels change their names for a month or so (sky greats become sky star wars and then goes back to sky greats). I could leave it just as sky greats, but I like the guide to be accurate. I have no problem getting the listings, logo and changing the channel name (in the xmltv file), the problem I have is the channel will not appear in the categories under movies, if I change the channel name.
Now I know I can just add it each time they change, or I could create a separate channel and just hide it, and unhide the channel when the name changes, but I am setting this up for my dad as well, who lives elsewhere, and I'm setting it up so he can just use it, without having to change things.
Anyone have any ideas about this?
The easiest way to have complete control over a remote device is to add the stream url for the channel into the xmltv channel element. That has been possible since the original TV Guide and should work in all of them.
eg
You can also force the channel mapping remotely by making a mapping file or m3u in Settings \ Optional.Code:<channel id="BBC News">
<display-name lang="en">BBC News</display-name>
<url>http://www.tvguide.co.uk</url>
<stream>http://a.files.bbci.co.uk/media/live/manifesto/audio_video/simulcast/hls/uk/abr_hdtv/ak/bbc_news24.m3u8</stream></channel>
It has happened again, but I think I know where the issue is, just want confirmation before I change things my end,
In my guide.xml, I have set the channel id to be the channel number, so I only change the display name. Is this why it is not staying in the category? If so, I will change back to channel id being the channel name, and setup channel numbers in the settings instead
2017-02-22, 10:13
(2017-02-22, 08:01)gillmacca Wrote: [ -> ](2017-02-17, 16:14)primaeval Wrote: [ -> ](2017-02-17, 15:46)gillmacca Wrote: [ -> ]Let's see if any of you guys can come up with a solution for this.
eg
The channel categories filtering is based on the name of the channel.
If you change its name add the new name to
userdata\addon_data\script.tvguide.fullscreen\categories.ini
by hand or by adding it to a category in the guide.
It probably should have been by id but it's not.
2017-02-22, 10:16
(2017-02-22, 03:24)sbougie Wrote: [ -> ]Can someone tell me where is the export folder when you export the channel mapping
It ends up here:
userdata\addon_data\script.tvguide.fullscreen\custom_stream_urls.ini
Most things end up in the addon data folder.
2017-02-22, 17:22
(2017-02-22, 10:13)primaeval Wrote: [ -> ](2017-02-22, 08:01)gillmacca Wrote: [ -> ](2017-02-17, 16:14)primaeval Wrote: [ -> ]The easiest way to have complete control over a remote device is to add the stream url for the channel into the xmltv channel element. That has been possible since the original TV Guide and should work in all of them.
eg
Ok, thanks for the info. I'll revert back to channel id being channel name
2017-02-25, 15:02
Hi, could you assist me with the timezone offset of the channels please?
I'm grabbing the EPG data myself and in my xmltv file, the offset seems correct after I set it up in the ini file.
for example - <programme start="20170225020500 +0200" stop="20170225040000 +0200" channel="Sky ActionUK">
But no matter what I do the TV Guide Fullscreen doesn't take this into consideration. Is there something I can do?
Thank you in advance
2017-02-25, 15:15
(2017-02-25, 15:02)Mimomaj Wrote: [ -> ]Hi, could you assist me with the timezone offset of the channels please?I don't think the guide reads the time offset. Assuming you are using Webgrab++ you can use WG2MP to correct the xml file, this might help solve the problem. See here http://www.webgrabplus.com/download/utility/wg2mp
2017-02-25, 18:57
(2017-02-25, 15:15)FXB78 Wrote: [ -> ](2017-02-25, 15:02)Mimomaj Wrote: [ -> ]Hi, could you assist me with the timezone offset of the channels please?I don't think the guide reads the time offset. Assuming you are using Webgrab++ you can use WG2MP to correct the xml file, this might help solve the problem. See here http://www.webgrabplus.com/download/utility/wg2mp
It does take the offset into consideration in parseXMLTVDate.
https://github.com/primaeval/script.tvgu...e.py#L1814
But there can be a lot of conversions going on depending on where the tv guide provider is based and where kodi and webgrab think you are.
2017-02-26, 13:08
@primaeval great to see you back. I am a using 0.0.306 as I see no need for me to update.
One feature I don't understand is the Background Update? What does it update? I was hoping it would update the EPG but I don't believe it does. I have to have EPG download 1 days info at each start of the guide as it is a safe way to ensure that anyone using it can just go back into the guide to make it download again. I use just one day as it's the quickest. I am using Schedules Direct.
Anyway does Background Update - update the EPG? because that would be handy.
Regards
DRT
Regards
DRT
2017-02-26, 14:14
(2017-02-26, 13:08)Drt1989 Wrote: [ -> ]@primaeval great to see you back. I am a using 0.0.306 as I see no need for me to update.
Regards
DRT
version 0.0.315
- Schedules Direct background update fix
- MySearch will first look for \userdata\addon_data\script.tvguide.fullscreen\favourites.xml
This should fix Schedules Direct background updates. I tested it with the update on login option and that worked.
Some of the other providers might not work either. xmltv and tvguide.co.uk seem to be alright.
If you use MySearch you can use your own version of the favourites.xml file in the addon_data folder.
If the guide finds it it will use that rather than the one in the addon resources folder.
2017-02-26, 20:01
Hi
Massive thanks to @primaeval for the addon and all the work involved - keeps getting better and better!
Can anyone point me in the direction of an online xmltv file to use with the addon please? Keep getting a blank screen with the thaisatelite one?
Thanks for reading and any help would be much appreciated
Danny
Danny
2017-03-03, 15:51
(2016-07-10, 17:29)unlocKing Wrote: [ -> ]AMAZING WORK!!!!
So easy to link channels from any addon to use with the EPG.
Unfortunately on my system, the addon browser do not work at all. Under the "addon" tab, not even a single addon is listed. The only way to connect addon streams is to first add the stream to KODI as favourite. Then in the EPG connect the stream from there. I have no idea what I have done wrong.
2017-03-03, 15:55
(2017-03-03, 15:51)kmengvik Wrote: [ -> ](2016-07-10, 17:29)unlocKing Wrote: [ -> ]AMAZING WORK!!!!
There won't be anything in the Addons tab until you add some addons.
In the next tab Browse find an addon folder with live tv channels then press Add Folder.
That will add all the streams in the folder to a file called addons.ini in your addon_data folder.
The next time you open Stream Setup the channels should be in the Addons tab.
If the streams match your xmltv channels you should get a chance to choose one when you play a channel.
2017-03-03, 15:58
your addons database may be corrupt. Time for a wipe
2017-03-03, 16:25
(2017-03-03, 15:55)primaeval Wrote: [ -> ]There won't be anything in the Addons tab until you add some addons.
Thank you for ultimate fast response. However, this way also fail, as I seem to be unable to browse folders. At the bottom of the "browse" tab I find the button "add folder". By clicking here I get a dialog proposing the following two options: "default" and "alternative streaming method". Then nothing again..
