(2018-11-22, 16:25)ködi-zömbie Wrote: [ -> ] (2018-11-22, 15:09)primaeval Wrote: [ -> ]Does teleboy work in the Kodi PVR?
yes
Did you install the right version of TVGF?
0.17.402 @ Kodi Leia Beta 4
Do other addons appear in Stream Setup\Addons when you add them from Browse?
yes
Do other pvr addon channels appear in Stream Setup\Addons when you add them with Import PVR (IPTV Simple Client etc)?
no. I tried Zattoo PVR. Its the same
EDIT: Tried IPTV Simple Client also not visable
Does it work if you switch Kodi to English?
There was a problem with the pvr urls at one point.
(2018-11-22, 18:49)ontap Wrote: [ -> ]Been a kodi user for years and only just found this duh , its excellent thank you , my only issue so far is "categories" , I have em listed top of egg and i can also access the long list of them on left after long pressing OK on keyboard , but when i click on a category it doesn't change ? am stuck on "all channels ", using an m3u and an xml file ? am I missing a setting ?
If there aren't any channels in the category it will go back to All Channels.
See if there are any Error messages in kodi.log if that is not the case.
cant open the cat's to see if they are empty , but checking the "all channels " section probably 70% of my channels aren't listed , wonder if downloading the file as opposed to using url will make any difference.
I run my m3u through a site ( subscription) that edits the listings and produces a custom url and xml.
(2018-11-22, 19:10)ontap Wrote: [ -> ]cant open the cat's to see if they are empty , but checking the "all channels " section probably 70% of my channels aren't listed , wonder if downloading the file as opposed to using url will make any difference.
If you can't see any ERROR messages in kodi.log have a look at the ini files in addon_data to see what is mapped up.
Categories:
userdata\addon_data\script.tvguide.fullscreen\categories.ini
Channel streams:
userdata\addon_data\script.tvguide.fullscreen\custom_stream_urls_autosave.ini
categories.ini is fully loaded , everything in there .
custom_stream_urls , 240 channels from a list of 501.
haven't done error log yet .
yes
yes
Try version 0.17.403
It was the pvr All Channels problem again. I thought that was fixed.
All Channels is translated into your regional setting so the pvr:// urls change too.
I've added a notification as well.
(2018-11-22, 18:49)primaeval Wrote: [ -> ] (2018-11-22, 16:25)ködi-zömbie Wrote: [ -> ] (2018-11-22, 15:09)primaeval Wrote: [ -> ]Does teleboy work in the Kodi PVR?
yes
yes
Yes, after switched to Eng US it added it to Addons after Import PVR>Save>Close>open again
(2018-11-22, 19:27)ontap Wrote: [ -> ]categories.ini is fully loaded , everything in there .
It's usually some unicode or special character that causes problems.
pm me your urls and I'll have a look.
(2018-11-22, 20:12)primaeval Wrote: [ -> ] (2018-11-22, 20:10)ködi-zömbie Wrote: [ -> ] (2018-11-22, 18:49)primaeval Wrote: [ -> ]Does it work if you switch Kodi to English?
Good.
See the post above: https://forum.kodi.tv/showthread.php?tid...pid2793934
Working great now with german language too. If I press Import PVR there is also an popup notification. Thanks for fixing
(2018-11-22, 21:14)ködi-zömbie Wrote: [ -> ] (2018-11-22, 20:12)primaeval Wrote: [ -> ] (2018-11-22, 20:10)ködi-zömbie Wrote: [ -> ]Yes, after switched to Eng US it added it to Addons after Import PVR>Save>Close>open again
Good.
Good.
There are at least a couple of normal addons for Teleboy that would integrate better into TVGF.
Have a look for plugin.video.teleboy and plugin.video.kodilivetv on github or google.
I'm wondering if it is possible to include channels that have an empty epg into ProgramListDialog? I added selectItem (on start so that it picks the selected channel from epg) to the list but indexing is wrong when channels are missing in list.
My script:
https://github.com/M89SE/script.mtvguide...ter/gui.py
(2018-11-25, 22:34)M89SE Wrote: [ -> ]I'm wondering if it is possible to include channels that have an empty epg into ProgramListDialog? I added selectItem (on start so that it picks the selected channel from epg) to the list but indexing is wrong when channels are missing in list.
My script:
I can't see what you've done. Have you got a diff between mine and yours?
Programs are pretty fundamental to everything in TVGF.
Is it xmltv channels with no program data at all?
