2019-08-06, 18:58
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
2019-08-07, 10:42
(2019-08-06, 18:58)M89SE Wrote: [ -> ]@moshoodo123@M89SE , thanks for your help so far, unfortunately, it still same result. below is my code after the edit.
Sorry I forgot about that, try adding this on row 9.
Code:s = re.sub(':00min$', '', s)
startDelta = datetime.datetime.now() - program.startDate
endDelta = datetime.datetime.now() - program.endDate
s = (startDelta - endDelta)
s = re.sub(r'^0:', '', str(s))
s = re.sub(r':00$', 'm', str(s))
s = re.sub(':', 'h ', str(s))
s = re.sub(':00m$', '', s)
matchHour = re.search(r'h\s\d+m$', s)
matchMin = re.search(r'^0\s\dm', s)
if matchMin:
s = re.sub(r'^0', '', str(s))
self.setControlLabel(self.C_MAIN_CALC_TIME_EPG, '%s' % (s))
Regards
2019-08-07, 11:22
2019-08-07, 22:05
@moshoodo123
This should do the trick, made a mistake earlier adding a colon.
python:startDelta = datetime.datetime.now() - program.startDate
s = re.sub(r':00$', 'min', str(s))
s = re.sub(':', 'h ', str(s)) #<--- Added a space after "h".
s = re.sub(r'00min$', '', str(s)) #<--- Removed 00min if single hour.
matchHour = re.search(r'h\s\d+min$', s) #<--- Added a "\s" after "h".
matchMin = re.search(r'^0\s\dmin', s) #<--- Added a "\s" after "0".
#if matchHour: #<--- Commented this with a "#".
#s = re.sub(r'min$', '', str(s)) #<--- Commented this with a "#".
if matchMin: #<--- Changed from "elif" to "if".
2019-08-08, 09:35
(2019-08-07, 22:05)M89SE Wrote: [ -> ]@moshoodo123@M89SE , you are a wonderful person. you just saved my life lol... that did the trick.
Thanks s lot
2019-08-09, 08:09
(2019-05-23, 20:36)Cangeoboy Wrote: [ -> ](2019-05-22, 15:32)francismm Wrote: [ -> ]How do i set this up?I sometimes get this error if I have a channel selected with foreign characters in its epg. See my post above. If you are able to remove that channel from your xmltv file then it may solve this problem.
I keep getting "oops, sorry about that". It was not possible to load program data, because the settings are invalid.
I used zip repository.primaeval-0.0.2
I load version 0.17.445
I don't know what i need to put on the settings considering there is no provision for username or password.
This is on Kodi 17.6 both on Windows and Android.
Probably need to add utf-8 encoding to the parser in TVGF, I think that should fix the problem of reading foreign channels.
2019-08-22, 00:04
(2019-08-08, 09:35)moshoodo123 Wrote: [ -> ]@moshoodo123 , are you using this script on Android box or on PC? just asking because it works perfect on my PC but the timing are not correct on Android, is show like 39h 3999999999 if using on android can you please confirm.(2019-08-07, 22:05)M89SE Wrote: [ -> ]@moshoodo123@M89SE , you are a wonderful person. you just saved my life lol... that did the trick.
Thanks s lot
2019-08-24, 00:30
With the loss of tvtv.us, I redid my epg source and then did a full reset of TV Guide Fullscreen. For some reason all of my logos are gone. I have a separate folder configured with all of the logos so I know they are there.
Is there some way to force TV Guide FullScreen to reload the logos?
Thank you
Thank you
2019-08-26, 09:55
(2019-08-22, 00:04)samueljones Wrote: [ -> ](2019-08-08, 09:35)moshoodo123 Wrote: [ -> ]@moshoodo123 , are you using this script on Android box or on PC? just asking because it works perfect on my PC but the timing are not correct on Android, is show like 39h 3999999999 if using on android can you please confirm.(2019-08-07, 22:05)M89SE Wrote: [ -> ]@moshoodo123@M89SE , you are a wonderful person. you just saved my life lol... that did the trick.
Thanks s lot
Try this, I haven't tested it myself but may work.
osAndroid = xbmc.getCondVisibility('system.platform.android')
if osAndroid is True:
s = (endDelta - startDelta)
else:
2019-08-29, 02:53
(2019-08-26, 09:55)M89SE Wrote: [ -> ]thanks @M89SE , i will test it and feed you back(2019-08-22, 00:04)samueljones Wrote: [ -> ](2019-08-08, 09:35)moshoodo123 Wrote: [ -> ]@M89SE , you are a wonderful person. you just saved my life lol... that did the trick.@moshoodo123 , are you using this script on Android box or on PC? just asking because it works perfect on my PC but the timing are not correct on Android, is show like 39h 3999999999 if using on android can you please confirm.
Thanks s lot
else:
2019-09-17, 10:55
Firstly a preemptive thank you for any help provided, its appreciated.
Very new user of Kodi.
Just setting up the live TV section and the tv guide is fairly basic. I was wondering if this one works for Sydney Australia free to air channels and if so how would I go about setting it up?? ITs currently all running and the pause, timeshift, record etc is all working, but I would like a more detailed tv guide and one with a lot more channels per page to avoid having to scroll too much.
So....will it work for Aussie channels....and will I still have the same recording options to select and record directly out of the tv guide?
Again thank you.
Again thank you.
2019-09-18, 21:52
(2019-09-17, 10:55)longworthdean Wrote: [ -> ]Hi,
Again thank you.
Seems the primordial one has been on a hiatus since last May. But to your question. To get TVGF to display channel / program data, you'll either have to find a provider, or learn how to install, configure and run the relatively complicated Webgrab+Plus software to generate your own XMLTV data files. Once you have either a local or remote a program data file, you can set the path to it in: Settings > Source.
To record, you need to find a copy of ffmpeg that works on your OS / device, and set its path and output folder in: Settings > Program Scheduler. You can also use Mr P's very handy IPTV Recorder Kodi addon.
2019-09-30, 02:32
Anybody know how to clear the Playlists? I've imported a couple m3u playlists in the Stream Setup screen, but would like to delete them.
2019-09-30, 02:36
(2019-09-30, 02:32)xDetoursx Wrote: [ -> ]Anybody know how to clear the Playlists? I've imported a couple m3u playlists in the Stream Setup screen, but would like to delete them.
First remove the m3u link then in settings go to reset and reset everything
2019-09-30, 02:41
Won't that also remove all linked channels, logos, channel order and categories?
