(2017-01-18, 12:07)primaeval Wrote: [ -> ]version 0.0.300
- Settings \ Appearance \ Up to Categories Bar
if skin has a Categories bar (use CatBar for now)
Setting to go Up to the Categories bar in the CatBar skin instead of wrapping round to the last channel.
Hello primaeval.
Can you explain me how to insert a channel list
And with portuguese guide as upload in photos
So I can upgrade through my server.
Because I saw an addon so modified and I liked it!!!!!
(2017-01-18, 12:35)kevinkevin Wrote: [ -> ]^^^
If you want to import that addons.ini file when the guide starts then add it in:
Settings \ Optional \ Import addons.ini \ addons.ini File.
It will merge it into the addons.ini file that you can create in:
Menu \ Stream Setup \ Browse \ ADDON \ FOLDER \ Add Folder
Then when you play the channel it should give you some options to choose from.
(2017-01-18, 11:42)primaeval Wrote: [ -> ]version 0.0.299
- NEW CatBar Skin
- to activate it map up the Show OSD action
- "CATEGORIES_BAR": ["ACTION_SHOW_OSD"]
- Keymap Editor \ Global \ Playback \ Show OSD
NEW skin: CatBar.
* Permanent Categories list.
* It needs the Show OSD action to be mapped up to a button to get to it.
@coolstud I'll have a think about getting to it with the up key later.
Sky listings have the categories included now, can the guide create the cat from the xmltv?:
<programme start="20170118003000 +0000" stop="20170118003500 +0000" channel="101">
<title lang="en">Weather for the Week Ahead</title>
<desc lang="en">Detailed weather forecast. Also in HD. [S</desc>
<category lang="en">News & Documentaries</category>
<category lang="en">News</category>
<icon src="http://epgstatic.sky.com/epgdata/1.0/paimage/18/0/webANXnewsweather7.jpg" />
</programme>
Complete Sky listings here:
http://tvstreamers.net/epg/networks/uk-sky/uk-sky.xmltv
(2017-01-18, 15:27)unlocKing Wrote: [ -> ]^^^
Program Categories uses that info in Search \ Category.
Send this plugin to see if you can later tell me how to do it
If it's possible to remove the links and insert my own links
I can make a big confusion, but I like to do it.
Because I have good links and this plugin fails the channels
I would like to know how to do it.
If I could help it was to add my addon
I always update it and I would like to share a job like this
For me this is a great job I like tvguide very much
http://www.filedropper.com/pluginvideotvguide
And I remember this plugin was not made by me
tanks for your support
(2017-01-18, 16:35)kevinkevin Wrote: [ -> ]Send this plugin to see if you can later tell me how to do it
I know you are Portuguese but I really can't understand what you are asking me.
What do you want to add to TV Guide Fullscreen?
[EDIT] Maybe you could post it in Portuguese and Google Translate or @
Hinkel could translate it.
Given the contents of the download link he posted, it sounds like he wants to use your guide to embed his channels into and distribute to the masses, and he wants you to tell him how to do it. I may be wrong of course.
Did he just give away his IPTV account?
(2017-01-18, 15:27)unlocKing Wrote: [ -> ] (2017-01-18, 11:42)primaeval Wrote: [ -> ]version 0.0.299
- NEW CatBar Skin
NEW skin: CatBar.
</programme>
great job tanks .
its ok your tvguide full screams work 100%
(2017-01-18, 18:09)kevinkevin Wrote: [ -> ]great job tanks .
I might change it's name to that. It drives me a little crazy sometimes. lol
I've just reinstalled my kodi (messed some things up), and I'm trying to get meta to download to use in this guide.
Can anyone tell me if the repo is working ok, as I keep getting installation failed when trying to install meta
(2017-01-17, 10:14)primaeval Wrote: [ -> ] (2017-01-17, 03:21)Scott00007 Wrote: [ -> ]Great work on the addon.....thanks for the continuous development!!
One little thing....every time there is an update the show the date in long form always gets checked. It would be great that if I turn it off it stayed that way from update to update.
It should be long by default. Here it is in the settings.xml file.
<setting id="date.long" label="Show Long Date in EPG" type="bool" default="true" />
This is where it sets the date format:
https://github.com/primaeval/script.tvgu...i.py#L2630
and this is the function that depends on the system region.
https://github.com/primaeval/script.tvgu...i.py#L3329
I can't see how it could be resetting it on a new version.
That is the only place that label is set.
Are you using the default skin?
[EDIT] Does it look like this in userdata\addon_data\script.tvguide.fullscreen\settings.xml ?
<setting id="date.long" value="true" />
The "issue" I was talking about is that the long date overlaps the time so I use the short date. Every update it gets set back to use the long date. I just want the settings I set not to change update to update. The OMdb Image and plot search and the TVDb/IMDb image search options in Lab 1 are reset every update as well.
Overall I just want things that I choose to stay the same......but that being said constant development is much more important. Just my 2 cents....well I live in Canada and we don't have pennies any more....so my 5 cents I guess lol.
(2017-01-19, 00:21)Scott00007 Wrote: [ -> ]The "issue" I was talking about is that the long date overlaps the time so I use the short date. Every update it gets set back to use the long date. I just want the settings I set not to change update to update. The OMdb Image and plot search and the TVDb/IMDb image search options in Lab 1 are reset every update as well.
None of these settings have changed in a long time.
Check if your settings.xml file is read-only.
Make a Settings change and see if the settings.xml file gets updated properly with a new value.
Maybe there is a corrupt setting in there.
Try deleting or renaming settings.xml and starting with a fresh file.
It could be as simple as a unicode problem with French characters in the file.
If you can isolate that with some tests I can fix it.
Have you ever installed a version directly from Github?
Things can end up in the wrong addons folder then.
Is anyone else seeing this behaviour?
(2017-01-18, 21:58)gillmacca Wrote: [ -> ]I've just reinstalled my kodi (messed some things up), and I'm trying to get meta to download to use in this guide.
I just did a fresh portable install of Kodi Jarvis 16.1 Win32 and Meta from repository.meta-1.0.0.zip installed fine.
(2017-01-19, 10:01)primaeval Wrote: [ -> ] (2017-01-18, 21:58)gillmacca Wrote: [ -> ]I've just reinstalled my kodi (messed some things up), and I'm trying to get meta to download to use in this guide.
Weird. I'm getting the same error on my amazon fire tv and my laptop
