Full Version: Already started recording on this channel
Hi.
I have unusual problem with deleting recording, not sure is this a TVheadend addon (2.2.16) problem or Kodi (16.1 Jarvis).
Let's say I want to record something, I use Guide in Kodi, select program and show and then I press Record on remote (ctrl+r), but I made a mistake and selected wrong show, so I want to delete timer. Pressing ctrl+r in most of the case ends with "Already started recording on this channel", but sometimes deleting is successful.
If I try to delete timer by pressing "i" (information), and then selecting "record" (notice that in menu "record" button should be "Delete Timer") timer is deleted.
Logs: http://pastebin.com/gU6zZuv1
I think it's easy to reproduce this, just press two times ctrl+r on some entry in Guide.
Regards.
This should be fixed with Kodi Krypton alpha 2. It would be great if you could test and report back.
Hi.
I tested it with Krypton aplha 2 on Windows 7 and it's working great!
Cool. Thanks for confirming the fix.
