I am using an external HD to create a digital slide show from Pictures. I have clicked the option to Randomize but it does not seem to be working. All of the other options like transition time and zoom effects seem to work but the pictures and videos seem to stay in the same order. Any thoughts or suggestions?
on the folder with pictures use "C" button and from the contecxt menu "recursive slideshow".
it is working for me.
Peppe
Hi thanks for the reply? Is that using the screen saver menu? I am using the actual Pictures menu and it only says Start Slide Show, not recursive slide show.
Thanks again for your help.
no screen saver, from picture section, after you added your images path using the context menu on a folder you can see
this!
Peppe
