2016-07-14, 18:54
2016-07-14, 18:57
So are you using Windows or Android? Your title says Windows but you've posted in the android forum.
What shows are you referring to? Locally stored? If not where are they located?
2016-07-15, 08:46
Kodi on Android gets the date from the OS, and the OS typically gets the date from the internet. Most phones/tablets keep the correct date because of their own batteries, but set top boxes don't have a battery. In other words, there's no real-time clock (most computers have a small battery and circuit called a real-time clock that allows them to keep time when they are turned off).
Find out why Android can't update the correct time/date, and everything else will fall into place.
2016-07-15, 20:59
Did your router go down? mine does this when that happens just reset bot the box and router and should be good
