Full Version: Stuck in "incompatible due to unmet dependencies" loop on opening
Hi, I have Kodi 16.1 (Jarvis) I believe (I can't check at the moment) on my INL3D box.
I just ran into an issue starting today that when I open Kodi, it shows a pop-up saying "Add-on is incompatible due to unmet dependencies. Would you like to disable it on your system?" for one add-on, and I just hit no or the return button on the remote, but then it shows the same message again and again for all of my add-ons in a never ending loop! There's no way to get out of it to go to settings or anything either. I even tried going to the home menu of my box to go to settings and force stopping Kodi, and then when I started it up again, it did the exact same thing again!
Any help is appreciated.
(2016-07-15, 03:51)the1tesfan17 Wrote: [ -> ]Hi, I have Kodi 16.1 (Jarvis) I believe (I can't check at the moment) on my INL3D box.
any help?
(2016-08-30, 04:07)khesjayy Wrote: [ -> ]
any help?
Delete Kodi and all the piracy addons and install Kodi 16.1 from the Play Store.
