Full Version: Where to find new sundtek-mediatv drivers?
Hello,
I have two Sundtek MediaTV Pro III Stick connected to Raspi2.
I am using:
  • LibreElec 7.0.2
  • Kodi 16.1
  • Sundtek Driver 7.0.102
During booting a message showed up in lower right corner:
"Sundtek: New driver version exist, update manually"
Where to find this new driver and how to udate?
Many thanks for assistance.
Regards
kkarsten62
Under Addons find addon Sundtek MediaTV, select Configure, then Driver and click on "Update from web... (press me)". You should see Kodi notification.
Probably reboot is needed just in case (forgot how exactly addon si working).
this seems to be the trick ...
Message disappears during booting, but Sundtek Driver version is still 7.0.102.
7.0.102 is addon version not actual sundtek driver version. You can check that with ssh running program mediasrv:
LibreELEC:~ # mediasrv --build
Build date: 2016-07-14 21:15:03
No response? Then I will assume everything is working fine.
Hi ultraman,
many thanks for your help. Everything seems ok with the Sundtek driver.
In a day or two new version of the addon will be pushed to repository. It will show driver version in addon settings to quickly spot the version.
