Full Version: Kodi 17 & Live TV
Pages: 1 2 3 4 5 6
I see 2 problems on Kodi 17 with live tv (other than this it works well).
1. With Mediacodec decoding of SD mpeg2 there is a slight 'bouncing' to the picture
2. With Mediacodec (surface) decoding of HD h.264 there are a lot of dropped frames and a news ticker goes into slow mo (it's really weird, knock of deinterlacing and the main picture stays the same, but the ticker goes super fast to catch-up).
These problems all occur on two different shields, both running 3.2 f/w.
Are they known bugs and if not what logs / tests would help to diagnose the issue?
Edit - these problems occur if the shield is in 4k or 1080 mode.
Debug Log as always, please
(2016-07-16, 14:08)fritsch Wrote: [ -> ]Debug Log as always, please
First log showing dropped frames on HD h.264 channel with mediacodec (surface) decoding:
http://pastebin.com/pBecnfa5
please start by installing latest available and try again
http://mirrors.kodi.tv/nightlies/android/arm/
And second log showing shaky / bouncy mpeg2 playback with only mediacodec decoding enabled:
http://pastebin.com/5e8nKVEH
FWIW I know shield 3.2 has issues, but the refresh rate is manually set to 50Hz and both methods work correctly in SPMC / Kodi 16
Anything else I can provide please let me know
(2016-07-16, 15:47)Martijn Wrote: [ -> ]please start by installing latest available and try again
Just updated and exactly same issues - shaky playback on SD MPEG2 with Mediacodec only and dropped frames on HD h.264 when (surface) is enabled.
Debug Log with newest build, please - the other one has a sever issue with non blocking renderer.
Edit: Btw. please use a recording for testing - no intention to debug possible additional tvh issues with the changed infrastructure.
Mediacodec with SD here:
http://pastebin.com/JutmGJk4
And surface with HD here:
http://pastebin.com/BuZcgmeB
(2016-07-16, 17:28)fritsch Wrote: [ -> ]Debug Log with newest build, please - the other one has a sever issue with non blocking renderer.
Oh Sad just seen your edit.
Will do some more logs in a bit
OK recorded HD with surface log:
http://pastebin.com/k6aMny5x
Recorded mpeg2 SD with mediacodec:
http://pastebin.com/Y92JLG4H
I'm all logged out Smile
I see everything in those logs ... but not playing a proper file. Plex is spamming like hell and tvh tells us its feeling about pvr recordings.
Here, three samples:
1080i50: http://solidrun.maltegrosse.de/~fritsch/..._h264-2.ts
576i50: http://solidrun.maltegrosse.de/~fritsch/...samples.ts
720p50: http://solidrun.maltegrosse.de/~fritsch/720p50_h264.mp4
(2016-07-16, 18:51)fritsch Wrote: [ -> ]I see everything in those logs ... but not playing a proper file. Plex is spamming like hell and tvh tells us its feeling about pvr recordings.
OK, give me some time and I will set up a clean kodi on my other shield and check these files.
Your SD mpeg2 clip with mediacodec only:
http://pastebin.com/AckEzeZB
Your HD 1080i h.264 clip with (surface):
http://pastebin.com/kmtVvLec
Note this shield is on a TV which can only do 720p (at 50Hz) in this case, I still see the same problem though.
1.) The bouncing is the missing, suboptimal / low quality deinterlacing, which is done by bobbing in the render. You use: Deinterlace (Auto) and Deinterlace-Method: BOB right? Does "Bob-invert" make a difference?
2.) Besides some sluggish startup I see that nearly every second frame is late and therefore dropped by renderrmanage :-( - sad. Someone needs to really properly look into mediacodec surface as it needs fine tuning after rework of render manager. Can't help.
Out of interest: http://solidrun.maltegrosse.de/~fritsch/...0_h264.mkv <- this one needs much more oopmh to play, does it also drop like hell?
Pages: 1 2 3 4 5 6
