Hi, I'm using the PVR IPTV simple client with live TV but I can't find a way to specify a location path for the recordings.
How do I do that?
I want to plug a USB drive into my fire tv and use it for recordings.
I'm a rookie with Kodi, but otherwise pretty technical.
Thanks for any advice.
I don't think iptv simple records (unless it has been added recently)
Which one can I use? I just want to save the live tv clips (which are streaming in) to a USB drive?
What do you recommend?
Tvheadend supports iptv feeds.
Thanks nickr. I was looking at the configure settings for TVheadend. I didn't see where you set a record location.
Does that typically happen in the settings for the PVR or somewhere else?
Well, If Like You Have An IPTV Account,
You Can Record To USB Using a New PVR Here:
http://forum.kodi.tv/showthread.php?tid=280968
It lets you choose your directory And It Records Really Well!
The PVR's Called XTCodes Client.
Take a look at the topic for more info!
But from what I'm getting, I think you are using windows?
If you are, unfortunately you have to be a tester to use it!
If not, you can download it for android in the link from that topic!
Hope this has helped you!
Thought I'd mention it here as well!
