Hi The_Ghost16
Thanks for having a look at this
I don't know if the "common" dir has anything to do with it
I have it included in the .rar file anyway
You can find the original scraper here:
http://www.download.c0m.nl/moviemeter.rar
The common dir has anything to do with it, yes:
<include>common/imdb.xml</include>
<include>common/tmdb.xml</include>
<include>common/movieposterdb.xml</include>
<include>common/impa.xml</include>
<include>common/dtrailer.xml</include>
I already sent the moviemeter.xml to Ghost but wasn't able to sent the common folder because I'm not at home. Thanks for uploading
okey, thanks for now
i'll be watching this closely
Gadus
Thank you very much for this great scrapper! Unfortunately, I have a little issue with the following movies as the scrapper doesn't download the fanart;
* Centurion (2010)
* Watchmen (2008)
I've already tried a refresh. It worked for some other movies, but not for these ones. Hope you have a fix. Thanks. Btw, I'm using XBMC (latest nightly)/MovieMeter scrapper ( 1.1.10) on ATV2.
Any update on the xbox scraper The_Ghost16 ?
Thank you
gadus Wrote:Any update on the xbox scraper The_Ghost16 ?
Thank you
I am curious as well, I logged this ticket on the xbmc4xbox trac, but am not skilled enough to edit the xml myself. For all of us keeping xbmc4xbox alive, we would appreciate the help, even though the xbox is not officially supported anymore
Because I changed my source, I had to update my entire library. Somehow the scrapper can't find covers/fanart from some movies that were found before while it's the same version of the scrapper. I already tried to refresh and to remove/update the specific movies, but no luck. Any idea how to solve this?
The movies are: Angels & Demons, Centurion, City of God, The Other Guys, Watchmen.
Thanks. I'm running one of the latest nightly's of XBMC on ATV2 using version 1.1.10 of the scrapper.
It seems that latest version of the scraper have issues with "’s" as it stops before the ' character with plot information.
example
drive (2011)
margin call
Drive (2011) & Margin Call (2011) should be correct now. If you have more movies with issues please let me know.
Currently no status update on the scraper for the xbox because i don't have much time to update my own xbox and test if i could get it to work.
Any update on the xbox scraper?
Who can help me out.
I've been using IMDB for the movies info.
Now my kids want this in Dutch. So I've enabled MovieMeter.
But how can I change all the movies in my database to scan with MovieMeter?
This movie gives a problem to "Percy Jackson & the Olympians The Lightning Thief(2010)"
benalla Wrote:Who can help me out.
I think you need to clear your library and then rescan it, that should work...
Any plans on adding. scraping the moviesets provided by themoviedb?
