2009-12-28, 19:31
2009-12-28, 22:15
binky11 Wrote:Hi,
You can use the following files:
My server is stable:http://www.megaupload.com/?d=Z07MR0VL
Thanks to the original poster
thanks, the files work great! although i'm having some issues with a lot of films
for instance:
lord of the rings (fellowship of the ring; return of the king)
moon
mirrors
request: would it be possible to get higher resolution movie pictures from impa awards for instance. the resolution from moviemeter sucks
2010-01-01, 18:00
Frankie great work! Altough it's really awesome to see dutch plot discriptions in XBMC, the artwork from moviemeter.nl is not that good. Do you think it's possible to combine an IMDB- and moviemeter scraper? It get's all it's info from IMDB and scrapes the plot from moviemeter.
I see little advantages in moviemeter over IMDB for the 'normal' movieinfo. It's possible that I'm wrong, in that case please explain.
Thnx again for your great work!
2010-01-02, 03:36
Problem solved....It were the .nfo files from the releases in which the imdb id was stated. Apparently XBMC now first checks the .nfo for imdb id....instead of checking the scraper first.
would still love to see higher resolution movie images though.
Thanx for the hard work
redje Wrote:thanks, the files work great! although i'm having some issues with a lot of films
for instance:
moon
mirrors
2010-01-03, 20:23
does this also work on the xbmc live installed version or only windows?
2010-01-06, 23:14
I did some changes tot the moviemeter scraper. You can download it here: http://www.megaupload.com/?d=85ZLW4GI
changes:
- using two search urls, one with quotes and one without quotes (this was needed to find the correct result for some movies, ex. Moon)
- putting search result wirh correct year on top of list
- got scraping movies starting with "the" to work by using "movie,the" in the search url
- scraping name, runtime, studio, overview, director, credits, actor, poster and fanart from tmdb
- scraping trailer from youtube
There still is a problem with movies containing french characters (ex. déjà vu).
I would like to use the imdb rating instead of the moviemeter rating, I see there is a function for it in the moviemeter api (film.retrieveImdb). Maybe somebody can add it to the php script so I can add the imdb ratings to the scraper.
Thanks to the frankied and binky11
changes:
2010-01-07, 02:06
the new posters, fanart and trailer capabilities are very nice! Thanks!
i do however have an issue with "movie,the" titles, still doesn't work for me. It finds the movies only at imbd.
2010-01-08, 00:05
2010-01-08, 00:17
Hi redje,
You don't have te rename the movie to "movie,the", the scraper will do this automatically when searching.
If you rename the movie folder to "movie (year)" and enable the option "Use Foldername for Lookups" it should work.
For example the foldername of the movie "The Mist" from 2007 should be "The Mist (2007)".
If you still have problems please post you debug log, so I can check what is the search url.
2010-01-08, 01:19
Hi revned,
Can you try this one: http://www.megaupload.com/?d=ZG2Y9NFL
The plot is now also in the outline tag.
2010-01-08, 19:36
Enochian Wrote:Hi revned,
I works perfect now! Thanks for your support!
2010-01-09, 20:10
Can't download: Het bestand dat u probeert te downloaden is tijdelijk niet beschikbaar.
2010-01-12, 00:31
Hi Enochian, thx for this great scraper!
I have one question. Is it possible to make the scraper look for an other url then 127.0.0.1. I have one webserver, that i use for different xbmc isntallation. I use it also for http-remote.
So can you make it configurable e.a. to let it search at 192.168.1.200 ?
2010-01-12, 10:25
Yesterday i finally got the time to work on my Moviemeter scraper. And it finally works and now i have all information that i want too have.
In the evening i will post some screenshots on how it looks in the confluence skin. Because i don't have access to my home pc here at work.
2010-01-16, 15:31
The_Ghost16 did you get it working because i read you wanted to post some screenshots and i'm very curious at those screenshots. Is it still needed to run your own website (server) in your configuration? Thanks in advance.
