Full Version: [Feature Request] narrow sideblade on vertical menu
I've set up Amber to use multiple backgrounds on most of the menus and am using the vertical menu to maximize how much of these backgrounds are visible. I find the sideblade & it's right hand alignment to push to far into the back grounds.
I've edited the file
includes_vertical_home.xml
to be narrower but each time amber is updated I loose my modification.
So I'm wondering if you'd include this option.
This has been my default skin for a long time now & I love it. This one small adjustment would make it perfect.
Thanks in advance. Thanks for considering.
In Krypton the main menu has been reduced from a width of 540 to 440.
We need to be careful as some languages may not fit in a smaller space and we want to cater for as many users as possible.
(2016-07-20, 17:56)joethepartylion Wrote: [ -> ]In Krypton the main menu has been reduced from a width of 540 to 440.
That makes sense. I hadn't thought about the issue of other languages. Isn't it all about ME ME ME??
Thanks for the response.
