2017-02-24, 11:38
(2017-02-23, 23:04)thezoggy Wrote: [ -> ]I'm not posting release names (like you are)
Touché. This is his mother. My son's been grounded for a week.
(2017-02-23, 00:18)thezoggy Wrote: [ -> ]Lang[i] = Lang[i].upper()
IndexError: list index out of range
(2017-02-23, 00:18)thezoggy Wrote: [ -> ]this went from:
Code:00:10:30,230 --> 00:10:34,265
but [Groans] this --
to: (double space after but)
but this --
this is too much.
(2017-02-23, 00:18)thezoggy Wrote: [ -> ]then with the CC cleanup, its not cleaning up the 'music' stuff like:
Code:00:14:38,544 --> 00:14:41,646
(2017-02-23, 00:18)thezoggy Wrote: [ -> ]then finally, looks like you need to add cleanup string for rarbg:
Code:00:18:02,838 --> 00:18:04,838
Torrent downloaded by RARBG
(2017-02-23, 21:49)HeresJohnny Wrote: [ -> ]3. The cleaning itself seems to fail partially. Example:
American.Horror.Story.S02E12.en.srt vs. American.Horror.Story.S02E12.en.srt_ORIGINAL
Cleansubs manages to clean the last lines of the sub which are
Code:728
00:42:42,598 --> 00:42:52,817
<font color="#ec14bd">Sync & corrections by honeybunny</font>
<font color="#ec14bd">www.addic7ed.com</font>
However, it fails to clean stuff from the top which still has
Code:1
00:00:48,917 --> 00:00:51,152
Daddy?
2
00:00:51,220 --> 00:00:53,788
Daddy'll be there in a minute.
3
00:01:48,608 --> 00:01:58,632
I'll be back with some more tests about NFS.
22:59:16.098 T:7864 ERROR: Previous line repeats 20 times.
22:59:16.098 T:7864 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'sqlite3.ProgrammingError'>
Error Contents: Cannot operate on a closed database.
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\default.py", line 1294, in <module>
if getDefinitions() != 0:
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\default.py", line 661, in getDefinitions
c.execute("SELECT definition FROM definitions")
ProgrammingError: Cannot operate on a closed database.
10:05:56.839 T:1652 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: string index out of range
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\standalone.py", line 290, in <module>
intCancel = scanPaths(manFolder, 1, 1, 3)
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\standalone.py", line 176, in scanPaths
process_subs(os.path.join(path, basePath, name), 1)
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\default.py", line 414, in process_subs
if not line.text[subsPos - 1].isalnum() or not line.text[subsPos + 1].isalnum():
IndexError: string index out of range
10:24:50.102 T:1596 DEBUG: CLEANSUBS STANDALONE >> FILE: >>Hannibal.S02E02.HDTV.x264-LOL.ja.srt<<
10:24:50.169 T:1596 DEBUG: CLEANSUBS >> SQL ERROR IN CheckDatabase
10:24:50.170 T:1596 DEBUG: CLEANSUBS >> SUB STATS WILL BE ADDED TO LOCAL DATABASE
10:24:50.178 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING utf-8
10:24:50.182 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1250
10:24:50.187 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1251
10:24:50.191 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1252
10:24:50.194 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1253
10:24:50.199 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1254
10:24:50.203 T:1596 DEBUG: CLEANSUBS >> ENC >> TRYING ENCODING cp1255
10:24:50.209 T:1596 DEBUG: CLEANSUBS >> ENC >> OPENED WITH ENCODING: cp1256
10:24:50.242 T:1596 DEBUG: CLEANSUBS >> SQL ERROR IN AddtoDatabase : no such table: stats
10:24:50.328 T:1596 DEBUG: Previous line repeats 2 times.
10:24:50.328 T:1596 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
(2017-03-14, 11:11)HeresJohnny Wrote: [ -> ]Thumbs up, Dalai Lanik :-)
CleanSubs just had a great run, cleaning a third of my subs until it errorred out. I think you're very close to perfection. Here's what I can glean from the normal log, will run some debug tests later to identify the subs which caused this.
Code:10:05:56.839 T:1652 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
23:39:19.204 T:9012 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\standalone.py", line 289, in <module>
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\service.cleansubs\default.py", line 417, in process_subs
